Portable power
2008-08-19 by Paul Schreiber
a) I have never seen a +-15V regulated wall wart. I have seen +-12V (they use a 5-pin DIN, a la MIDI). But this will not work with MOTM. b) your best bet is to get a 5U tall case, put a MOTM-900 in there, and leave it. Then, when needed, remove modules from the studio and place in there. Paul S.
2008-08-19 by Jonathan Snipes
Paul S.
2008-08-19 by Matthew Hiscock
What about the Dotcom QPS2:could easily switch out the power connectors with the MTA 156 ...-jOn Aug 19, 2008, at 9:49 AM, Paul Schreiber wrote:a) I have never seen a +-15V regulated wall wart. I have seen +-12V (they
Paul S.
Paul S.
2008-08-20 by Stephen Drake
Or there s always the extreme diy approach - http://www.musicfromouterspace.com/analogsynth/WALLWARTSUPPLY/WALLWARTSUPPLY.php This with one of Paul s
2008-08-20 by John L Rice
The smallest PowerOne that 'should' work is only about $50 (US$) as long as you need less than 400mA: http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=179-2306-ND Also, some very helpful related info here from Richard Brewster: http://pugix.com/synth/portable-rack-cabinets/ Best of luck! John L Rice PS - PLEASE understand, fear and respect AC current before attempting DIY power projects! Death awaits just a tiny stupid mistake away. (I've been REALLY lucky at least three times in my life . . . and I'm not generally stupid . . . unless it comes to credit cards . . .and especially women! ;-)
From: motm@yahoogroups.com [mailto:motm@yahoogroups.com] On Behalf Of Stephen Drake Sent: Tuesday, August 19, 2008 7:06 PM To: MOTM List Subject: Re: [motm] Portable power Or there's always the extreme diy approach - http://www.musicfromouterspace.com/analogsynth/WALLWARTSUPPLY/WALLWARTSUPPLY .php This with one of Paul's distribution boards and you'd be in business. Personally I'd rather be using Paul's 900 hardware than this however. On Tue, Aug 19, 2008 at 12:19 PM, Matthew Hiscock <audio@...> wrote: Perhaps this would do the trick? http://www.mouser.com/Search/ProductDetail.aspx?qs=vF2eI8GWwmUzYwDJYiRG1A%3d %3d Cheap, 240ma, +/-15v - I'd just have to deal with the 5-pin DIN in some way.... On 19-Aug-08, at 12:59 PM, Jonathan Snipes wrote: What about the Dotcom QPS2: http://synthesizers.com/q101.html#qps2 could easily switch out the power connectors with the MTA 156 ... -j On Aug 19, 2008, at 9:49 AM, Paul Schreiber wrote: a) I have never seen a +-15V regulated wall wart. I have seen +-12V (they use a 5-pin DIN, a la MIDI). But this will not work with MOTM. b) your best bet is to get a 5U tall case, put a MOTM-900 in there, and leave it. Then, when needed, remove modules from the studio and place in there. Paul S. __________________________________________________ -- ------------------------------------------------------------------ Stephen Drake sduck409@... makeme1witheverything@...
2008-08-20 by Matthew Hiscock
PS – PLEASE understand, fear and respect AC current before attempting DIY power projects! Death awaits just a tiny stupid mistake away. (I’ve been REALLY lucky at least three times in my life . . . and I’m not generally stupid . . . unless it comes to credit cards . . .and especially women! ;-)
2008-08-20 by Andre Majorel
On 2008-08-19 13:13 -0400, Matthew Hiscock wrote: > A MOTM900 would be much larger than what I'm thinking. I want > something *smaller and lighter* than my current setup. Switching power supplies are unbeatable for size and weight. They tend to be noisier than linear power supplies, but will the effect on your MOTM modules be large enough to be noticeable on stage ? -- Andr\ufffd Majorel <URL:http://www.teaser.fr/~amajorel/> Do not use this account for regular correspondence. See the URL above for contact information.
2008-10-14 by Matthew Hiscock
Hi all, I'm finding a clicking in the outputs of band 1 of my motm410. It clicks at the same rate as the built-in LFO, when it hits the low and high point of its cycle. I get it in Out 1 and Mix Out but not Outs 2 & 3. It might have always been there, but recently I've started using that filter to process guitar, so the signal is rarely the full 5v, and there's no envelope shutting off the output when I'm not playing. When I put a full 5v osc. signal through, I don't hear the clicking at all. Probably still there but to far below the level of the signal to be audible. Do other people find this? I'm wondering if this is just a consequence of the filter design, or is there something wacky with mine specifically? thanks, Matthew
2008-10-15 by Paul Schreiber
Something is wrong, I have never heard of this in 8 years for shipping this module. Paul S. ----- Original Message -----
From: "Matthew Hiscock" <audio@...> To: "MOTM-list" <motm@yahoogroups.com> Sent: Tuesday, October 14, 2008 12:26 PM Subject: [motm] 410 clicking in band 1. > Hi all, > > I'm finding a clicking in the outputs of band 1 of my motm410. It > clicks at the same rate as the built-in LFO, when it hits the low and > high point of its cycle. I get it in Out 1 and Mix Out but not Outs 2 > & 3. > > It might have always been there, but recently I've started using that > filter to process guitar, so the signal is rarely the full 5v, and > there's no envelope shutting off the output when I'm not playing. > When I put a full 5v osc. signal through, I don't hear the clicking > at all. Probably still there but to far below the level of the signal > to be audible. > > Do other people find this? I'm wondering if this is just a > consequence of the filter design, or is there something wacky with > mine specifically? > > thanks, > Matthew > > > > ------------------------------------ > > Yahoo! Groups Links > > > >
