MOTM
Bracket design
Bracket design
2008-10-21 by djbrow54
I'm building the Jurgen Haible chorus and interpolating scanner into
a 2U module.  The panel is very dense and I was trying to figure out
the best way to mount the PCB.  I needed the PCB as far to the side
as possible so came up with a bracket arrangement that clamps to the
row of jacks.  It's basically a main bracket which screws to a short
strip that sandwiches the jacks.  It's quite sturdy.  I thought I'd
pass the tip along.  It will only work with a row of jacks but I have
several modules built that way.
There's a photo at the bottom of
http://modularsynthesis.com/jhaible/jhscanner.htm
Dave
Re: [motm] Bracket design
2008-10-21 by James Elliott
That sir, is bad ass!!!!!!!! Great job!!!!!
To: motm@yahoogroups.com
Sent: Monday, October 20, 2008 11:23:26 PM
Subject: [motm] Bracket design
http://modularsynth esis.com/ jhaible/jhscanne r.htm
Dave
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
Re: Bracket design
2008-10-21 by Charles Osthelder
Awe inspiring, really!  Where do you get clear shaft pots, because
that is just too cool.  I've got to unpack faster and build something
with that design element.
Fine business as always, Dave!
Chub - currently trying to empty his garage
> From: djbrow54 <davebr@...>
> Dave
> Do You Yahoo!?
Re: Bracket design
Mouser 313-1400F-100K
The feel is good.  The nut is crap - lots of slop.  The threads are
cut square on the bushing so the nut only grips on 4 sides.  They
will fit through the 1/8" panel with a lock washer on the back - but
just barely.  On one I had to leave the front washer off so I could
grip enough of the threads.  That's one of the reasons I used the
perf board on all the pins so it would help secure them.  The pins
are very thin and not on 0.100 centers.  I have not found a data
sheet so have no dimensions (so I could buy new nuts).
The front of the shaft has a screwdriver "indent" which is kind of a
bummer since that's what is visible as the light pipe.  I really
would like to find some nice red inserts that would fit into the
hole in the end of my knobs.  Maybe someday I will run across some.
The shafts are probably just a bit long and could be cut down (or
ground down).  That would eliminate the screwdriver indent but I
wasn't brave enough to try this on these potentiometers.
Dave
--- In motm@yahoogroups.com, "Charles Osthelder" <chubtoast@...>
something
> > From: djbrow54 <davebr@>
into
out
side
short
I'd
have
> > Dave
> > Do You Yahoo!?
