[motm] Polyphonic Formant Shifting
2008-11-24 by Kenneth Elhardt
Might as well put up the audio files below for completeness as it's part of the artifact-free resynthesis pitch shifting I was doing and is the major step in what I should shortly be able to do, which is grabbing formants from real sounds, optionally editing them and then applying them to synthesized sounds (part of my advanced filter bank project). In these audio samples I'm doing formant shifting and formant correction on polyphonic audio, which as far as I know, there's nothing out there that can do that, nor does anybody probably even think it's possible. I had doubts myself. Here's a guitar, 1st in it's original state, then with formants shifted 70% (that would be down), then 130%, then 190%. http://home.att.net/~elhardt3/GuitarFormantShifting.mp3 Here's a male/female chorus first in it's original form, then resynthesized using 53 sinewaves, 1st pitch shifted down a few semitones while shifting formants on polyphonic materical up the same mount to keep them constant, followed by pitch shifting up and shifting formants down to again keep them constant. http://home.att.net/~elhardt3/Choir_With_Formant_Correction.mp3 Here's the choir shifted down then shifted up without formant correction for comparison purposes. Particularly noticable is the female voices starting to sound like children in the shifted up part. http://home.att.net/~elhardt3/Choir_No_Formant_Correction.mp3 When I get back to work on this stuff, hopefully I'll have a demo of the MOTM with formant filter info from real instruments applied to it. -Elhardt
