FW: [motm] Need help on planning MOTM modular.
2009-02-06 by Tkacs, Ken
>>>Hello, I'm looking to start a MOTM modular system, but I'd like to have a VC-ADSR module.... ----- Besides the third-party offerings that have been suggested, I'd just like to mention that there are indirect ways of achieving many useful VC-EG effects using combinations of other modules. For instance, running the envelope generator through a VCA, and sometimes also applying voltage-controlled 'lag' to a punchy envelope. Often two carefully-adjusted EGs in parallel, with some of these effects applied only to one of them, is just the ticket (kind of a "Carlosian" approach). For simple VC-AR envelopes, just look at the VC-Lag module and think about processing the Gate logic directly. (After all, what is an ADSR module but a very specific arrangement of lag-time integrators, you know?) It takes some experimentation but you can achieve some really expressive effects with tricks like these. (I'm a nut for envelope generators... I don't think you can have too many in a system. I can easily clear a room when you get me talking about envelope generators...) Hope this helps.
