installing a 960?
2009-06-12 by patchdub1972
hi folks. whats the best way to go about installing a 960 to the 900? thanks!! -patch
2009-06-12 by John L Rice
Possibly the easiest way if there is enough slack on the MOTM-900 wires would be to cut the 3 wires going from the supply to the distro board in half, strip the ends prepare 3 new pieces of wire with stripped ends long enough to reach your 960 and then use wire nuts to connect the ends together. Not crimping or soldering required. Now, what the 'best' method is I can't say! ;-) Best of luck, John L Rice
-----Original Message----- From: motm@yahoogroups.com [mailto:motm@yahoogroups.com] On Behalf Of patchdub1972 Sent: Thursday, June 11, 2009 7:38 PM To: motm@yahoogroups.com Subject: [motm] installing a 960? hi folks. whats the best way to go about installing a 960 to the 900? thanks!! -patch ------------------------------------ Yahoo! Groups Links
2009-06-13 by patchdub1972
this is from paul and i thought i would pass it on... "Use a MOTM-20 or -30 jumper cable (just plug them together)." probably because this involved power i was expecting something a little more complicated. i am always very relieved after i build a module and power it up for the first time there are no sparks or poofs of smoke! -patch --- In motm@yahoogroups.com, "John L Rice" <Drummer@...> wrote:
> > Possibly the easiest way if there is enough slack on the MOTM-900 wires > would be to cut the 3 wires going from the supply to the distro board in > half, strip the ends prepare 3 new pieces of wire with stripped ends long > enough to reach your 960 and then use wire nuts to connect the ends > together. Not crimping or soldering required. Now, what the 'best' method is > I can't say! ;-) > > Best of luck, > John L Rice > > -----Original Message----- > From: motm@yahoogroups.com [mailto:motm@yahoogroups.com] On Behalf Of > patchdub1972 > Sent: Thursday, June 11, 2009 7:38 PM > To: motm@yahoogroups.com > Subject: [motm] installing a 960? > > hi folks. > > whats the best way to go about installing a 960 to the 900? > > thanks!! > -patch > > > > ------------------------------------ > > Yahoo! Groups Links >
