MOTM
FS -- Modcan CV Recorder 57B, modified for three voltage MOTM power supply
2012-10-13 by Richard Brewster
I am not making good use of this interesting module, so I've decided to sell it.
Here's my page describing it:
http://pugix.com/synth/modcan-cv-recorder-57b/
I made three modifications.
It has MOTM-style knobs, but I will include the original knobs, or ship only the originals if desired.
I did the grounding mod, so that all the panel jack grounds are connected to the power supply common.
It uses external +5V power, instead of deriving it from the +15V supply with an onboard regulator. This cuts the +15V current requirement down to 45ma. Bruce Duncan assembled the board this way for me; I did not modify the circuit board myself.
I will include an adapter power cable that plugs into the 6-pin MOTM 3-voltage connector (like those used with the MOTM-950/960). You might have to make up a custom power cable if this one doesn't fit your system. It does require the +5V power supply, which you will have to provide.
The current Modcan price list shows this item at $698.78. I'm asking $498.00 USD, plus $10 U.S. shipping or $50.00 overseas shipping.
Thanks for your interest!
Richard Brewster
http://www.pugix.com
Re: [motm] FS -- Modcan CV Recorder 57B, modified for three voltage MOTM power supply
Hi all,
I have two people interested in this and expect one of them will buy it. I'll let the list know when it's sold or happens to be available again.
Richard
Richard Brewster
2012-10-20 by Richard Brewster
Both of the potential buyers backed out. So this is still available.
Richard
On 10/13/12 5:06 PM, Richard Brewster wrote:
Hi all,
Richard
Richard Brewster
