E355/F355 Nut Size?
2012-12-15 by emmaker
Happy Holidays Everyone, I'm putting together a F355 DIY Morphing LFO. I can't find the nut size in the P260T datasheet and the NKK switches don't have the bushing size marked on them so I can't tell if they are 1.4" or 6mm. Would someone know the nut sizes for these? FYI: The LED spacers put the LEDs above the mounting surface for the pots and switches. If you are putting one of these together from scratch you'll need something to raise their mounting surfaces above the LEDs. I'm going to put some nuts behind the panel and use those to raise the mounting surface. Thanks in advance. Jay S.
