Flat rails
2000-02-03 by Paul Schreiber
> > Sigh, I feel like a broken record but the right answer for this is to use > wood for the structural support and a simple flat rail attached to it for > mounting modules. The current rails are fantastic for rack mounting where > the slop in the cabinet can be tolerated by the mechanics of the side rails > but it becomes harder when you try to mount those rails where you have > tighter tolerances. The issue I need to look at is that Moog panels are only 0.050 alum. and MOTM is 0.125 al or about 5X more weight, when you toss in the steel pcb bracket. Moog uses itty-bitty screws that are short enough so that (panel thickness + rail thickness) < screw length and it remains to be seen if a standard length screw can be made to work with MOTM panels in this fashion. It's not that the Moog system is a "bad idea", it just might not be suitable in this case. (PUN alert!) Paul S.
