Sequencer knobs
1999-04-04 by Paul Schreiber
A standard cheap seq uses cheap pots from +5 to ground to get the CV out. Problems are as follows a) It can be hard to tune to a exact note over a 5 octave range with a cheap pot b) they drift with temperature. Since they are used ratiometric this is minimized to a degree. What I am looking at is a Greyhill optical encoder. It is small, like the black Spectrol pots I use now. It is sealed. It outputs 256 pulses per revolution, nice and clean. And, (this is the SEX part) it has a built-in pushbutton integrated with the shaft! You push the shaft in about 1/16" and it clicks like a mouse button! If fact, this is the model they used: spin the knob, and click to set the value. I LOVE this stuff!! Of course, it is NOT cheap. If I buy 500 at a time, the cost to ME is about $14 each. YEP! $14 EACH!!!!!! But they are good for 5 MILLION rotations and the built-in button is just to cool for words. Paul S. -----Original Message----- From: Gur Milstein <gur-m@...> To: motm@onelist.com <motm@onelist.com> Date: Saturday, April 03, 1999 6:34 PM
Subject: [motm] Re: MOTM up date >From: Gur Milstein <gur-m@...> > >Paul. >please explain more about the sequencer desighn problem,why would >quality components would make an analog sequencer better ? >is it only the pots drift problem or are ther any other importent >aspects ? > >thanx >Gur Milstein > >------------------------------------------------------------------------ >To unsubscribe from this mailing list, or to change your subscription >to digest, go to the ONElist web site, at http://www.onelist.com and >select the Member Center link from the menu bar on the left. >
