Re: VC EG... now other things
2000-02-15 by Tony Allgood
>First, hello to Tony (master of the 303) A. More of a slave really :-) Actually, I don't have one, not a real one anyway. >maybe you can answer last weeks question about a 303 audio output being used as a GATE signal? I have never tried it, but it perhaps could if you used the headphone out. You normally need a couple of volts to trigger a gate. But, it wouldn't be clean trigger at all. Hasn't the TB got a gate output to use anyway. But I have missed most of the thread here... As for bi-colour LEDs, love them to bits. Its always best to put them in the feedback path of an op-amp, that way you don't get any dead bits for low level signals. The problem is just how much current do you want the little critters to have. I reckon 5 to 10mA is about the best to have reasonable brightness and not too much current drain. Hard to see (groan) how you could use one on a standard unipolar ADSR though. But we could always try. Regards, Tony Allgood Penrith, Cumbria, UK MidiDAC midi-cv, Modular bits, TB303 clone and Filter Rack http://www.techrepairs.freeserve.co.uk/projects.htm
