Labeling mods
1999-01-25 by CHRIS PARKER
Greetings MOTM builders!!! Has anyone (everyone?) else added the Vibrato Source Select Switch modification to the MOTM-100 Noise/S&H module? If so, how did you handle labeling the new switch? I'm looking for some way that will do justice to these beautiful panels! Thanks!
1999-01-25 by Paul Schreiber
As a general answer: the font is called "Alternate Gothic 2". This is the same as the Moog modular. Originally, a company called ChartPAK make rub-on lettering with this font. I used to buy these, by the sheet, at local college bookstore. About 1 year ago, I was at an "old fashioned" drafting supply store (pre-AutoCAD) and lo and behold, there was a small rack of ChartPAK letter sheets. Paul S.
1999-01-25 by Thomas Hudson
I've spent the last two weeks setting up a LAN in my home w/ full time access to the Net. As soon as the seemingly never-ending sysadmin nightmare is over, I plan on setting up a MOTM page to collect modifications. I have two so far; 1) MOTM-100 : Vibrato Source selection switch 2) MOTM-120 : AND/XOR Switch and daughterboard The labeling has been my main hesitation. I'll save this tip to add to the MOTM page. BTW, is this list archived? Thomas P.S. You can see the not too pretty fruits of my labors at http://www.tomy.net . Not much, but at least the web server is up and running. Mechanics before beauty, er, content. Paul Schreiber wrote:
> > From: "Paul Schreiber" <synth1@...> > > As a general answer: > > the font is called "Alternate Gothic 2". This is the same as the Moog > modular. > Originally, a company called ChartPAK make rub-on lettering with this font. > > I used to buy these, by the sheet, at local college bookstore. About 1 year > ago, I was at an "old fashioned" drafting supply store (pre-AutoCAD) and lo > and behold, there was a small rack of ChartPAK letter sheets. > > Paul S. > > ------------------------------------------------------------------------ > To unsubscribe from this mailing list, or to change your subscription > to digest, go to the ONElist web site, at http://www.onelist.com and > select the User Center link from the menu bar on the left.
