Re: [motm] Mixer
2000-03-17 by jwbarlow@aol.com
In a message dated 3/16/2000 5:30:19 PM, PaulBr@... writes: >It seems to me that this "internal" switching stuff is just asking for >confusion. I mean, if I want two 3x1 mixers, that's what I want to plug >into. If I unjack the out of the 2nd mixer for a moment, I surely won't >be >expecting the other 3 channels to suddenly route into the first mix. And >if >it subtle enough, I'll sure as hell end up with a well-scratched head. > I'm >a much bigger fan of the "external" switch idea. Try this on for size: This idea came about after a lengthy (heated) debate over the development of a MOTM mixer about a year ago -- the main problems being price/utility. If, for example, you build a three input/one output (with a master volume) it'll be at least $90 (and one mixer is not nearly enough). If you think of a stereo mixer as being two mono mixers with common inputs you can see how this idea started. I have to admit, I agree with Larry that the output pots are the least useful items of a modular mixer, and when this debate was raging, I suggested the most simple 1U mixer (3 inputs, 2 input attenuators -- one at unity gain, and one output) maybe the cheapest MOTM module available. But the 2U 6X1/3X2 mixer would be extremely versatile, and I think a lot of us on this list could use a versatile mixer right now since there isn't a MOTM mixer available yet. >You have 6 inputs, 2 outputs, and a switch. When the switch is in position >"A", you have a 6x1 mixer, with the 2nd output being the same as the first. >This might be useful for, say, sending to two destinations w/o using a >multi. OK, that's not much of a bonus, exactly, but its better than having >the 2nd output just mute. When the switch is in position "B", you have >two >seperate 3x1 mixers, completely independant. I don't know about the master >control, but your idea would likely fit well. In essance, we're thinking >of >the same thing, the switch is just moved from being toggled by the presence >of a jack to a mounte switch. Not a bad idea, but I seem to recall the output pots having friends in "high places" if you know what I mean. For a 2U panel, there are currently 8 pots and 8 jacks and not a place for a switch anywhere -- that's when the idea of the normalizing jack came into play. >You might argue that internal switching will lead to greater accidental >discoveries, and that's a possible point. However, I am quite prone to >flipping switches and rotating knobs, so personally I'd much rather flip >a >physical (sp?) switch than go crazy trying to figure out that strange >"bleedover". Bradley wanted a pot which retracted into the front panel when not in use. My apropos suggestion, given the vocal advocates of one or another of the features, was a much more cost effective way, a sample of Moe Howard saying "wrong knob, numbskull!" when no plug was inserted. But then again, I know Crow doesn't like samplers. JB PS, PaulBr, let me know what you're thinking about as far as mults -- I've got as many useful ideas about mults as I did about the mixer! I liked the 16 holes with two ganging switches for either a 4X4 mult or up to a 2X8 mult.
