Multiples/Attenuator
2000-03-21 by Frank Vanaman
Hi everyone-- I've stuffed up a sorta mediocre looking picture of my first attempt at a MOTM form factor panel. It's a quad attenuator with 2 four way multiples. The attenuator is normalized, so that if you plug something in to input 1, the pots for 2, 3 and 4 also get the signal; plugging something into input 2, for example, breaks the chain... I put the pots on the right (since 2U wide MOTM modules seem to favor the right side first), with the attenuator inputs and outputs on the left. At first I was going to run the pots down the middle with the inputs on the left and the outputs on the right for a more intuitive look, but it occurred to me that if I were to want to turn one of those knobs, there would most likely be cables plugged in to its respective 'in' and the 'out', so I went for access over 'intuitivity'. It's a regular aluminum panel, 2U x 5U, actually from a 2U wide 19" panel which I sawed down to produce 2 panels each 2U x 5U. Sprayed two coats of black (semi gloss) with those pesky white chartpak type rub-on letters, and followed by a coat of clear matte lacquer. I'm not sure the lacquer 'likes' the black paint, because the whole thing got very slightly crinkled but that look is actually a bit closer to the MOTM finish than a flat featureless surface... In the photo, it sorta looks like the labels were added on by a three-year-old, and all I can say in my defense, is that the whole mess looks a bit better in person! http://216.254.67.249/projects.htm#MOTM for those who might want to take a peek. The bottom two photos show the new panel. For my next act, I'm planning an overlay in closer-to-MOTM style (and featuring the radial tick marks and 1-10 legends) for a 1U wide panel to hold my trusty PAiA 'Roctave Divider'! No, really! Frank Vanaman Baltimore, MD
