MOTM
FLASH! First MOTM-320 pics
1999-05-05 by Dave Bradley
Taken at a secret test track facility near Ft. Worth, Texas...
I took the liberty of rearranging a few things from the original proposed
layout in Paul's email:
1. The waveform rotary switch is history.
2. Jacks are rearranged to reflect more closely the MOTM-300 layout.
3. All pots were moved to the pcb side. If it looks too unbalanced to
everyone, a pot or pots could be moved to the left column, but then you have
to wire it up manually<g>!
4. Lots of panel space left over for a reset button or other goodies...
Dave Bradley
Principal Software Engineer
Engineering Animation, Inc.
daveb@...
Re: FLASH! First MOTM-320 pics
1999-05-05 by Paul Schreiber
1) Move SHAPE MOD to left side by SHAPE. I don't like the bottom
pot position if I don't *have* to use it.
2) Change title to MOTM-320 Voltage-Controlled LFO
I'll post it on the site!
Paul S.
Try this. I cheated and titled it "MOTM-320 VC LFO" since "MOTM-320
Voltage-Controlled LFO" would have run longer than the "Synthesis
Technology" label above it.
Dave Bradley
daveb@...
> From: "Paul Schreiber" <synth1@...>
> Paul S.
