MOTM
RE: [motm] Purchasing decisions
2000-04-04 by Dave Bradley
> > 2. The Expressionist doesn't have true trigger outputs,
> > just gate. I don't find this to be an issue, if you use the
> > newer 800s or do the simple mod to the early 800s which
> > allows them to run a complete ADSR cycle from a gate
> > only.
> Yes, but only using triggers will allow re-triggering without prior note
> release.  This is probably the decision maker for some when deciding
> between the Kenton and Encore.  For Dave, the true triggers was not an
> issue.  For me, it was, so I bought the Kenton (and gave up the
> poly mode).
Don't take my comments about the Expressionist lacking true triggers to mean
that you can't retrigger on every note when playing legato. You can set it
up for either single or multi trigger. It just does it differently. The
Kenton outputs a trigger on a separate dedicated jack, while the
Expressionist closes the gate for a few microseconds and then reopens it.
You can't hear it do this, but it allows the EG to retrigger on each note
while playing a legato line. So the audible effect is identical.
Dave Bradley
Principal Software Engineer
Engineering Animation, Inc.
daveb@...
Re: [motm] Purchasing decisions
2000-04-04 by J. Larry Hendry
OK.  As a guy with only 1 420, you two 420 guys tell me how you hook up and
use two.
I'm all ears.
Larry H
> From: David Bivins <dbivins@...>
> To: motm@egroups.com
> Subject: RE: [motm] Purchasing decisions
> Date: Tuesday, April 04, 2000 7:21 PM
> Word. 2 420s is the way to go.
> > From: Christopher Jeris [mailto:cjeris@...]
> > Sent: Tuesday, April 04, 2000 3:36 PM
> > Subject: Re: [motm] Purchasing decisions
> > On Tue, 4 Apr 2000 thudson@... wrote:
> > > - Which modules would you most want duplicates
> > >   of? I was thinking of an extra 300, 320, and
> > >   800. I know I'll need more VCAs, are there
> > >   plans for a VCA other than the 110, or is
> > >   there merit in having more than one 110?
> > I don't think anyone else has mentioned this yet ...
> > Get two 420s.  One is very good, two are amazing.
> > Glassy overdriven resonant hell.
> > peace,
> > Chris Jeris
> > Get a NextCard Visa, in 30 seconds!
> > 1. Fill in the brief application
> > 2. Receive approval decision within 30 seconds
> > 3. Get rates as low as 2.9% Intro or 9.9% Fixed APR
> > Apply NOW!
> > http://click.egroups.com/1/2646/3/_/529958/_/954884166/
> LOW RATE, NO WAIT!
> Get a NextCard Visa, in 30 seconds!  Get rates
> as low as 2.9% Intro or 9.9% Fixed APR and no hidden fees.
> Apply NOW!
> http://click.egroups.com/1/2122/3/_/529958/_/954886735/
