MOTM
Re: [motm] Patch Panel
2000-04-06 by J. Larry Hendry
Steel wound be better because it would not wear from the repeated use.
LH
> From: Dave Bradley <daveb@...>
> To: motm@egroups.com
> Subject: RE: [motm] Patch Panel
> Date: Thursday, April 06, 2000 10:42 AM
> OK, I'll design the template and get some quotes on it. I'm thinking 1/8"
> aluminum or steel.
> Dave Bradley
> Principal Software Engineer
> Engineering Animation, Inc.
> daveb@...
> > > I have plans to drill a lot of panels for DIY
> > > stuff in the future. I'm going to a machine shop,
> > > have them cut a metal template for a 2U wide
> > > panel, and precision drill small pilot holes at
> > > every location an MOTM panel could have
> > > holes. Then I can simply bolt the template
> > > to a blank using the 4 corner
> > > holes, and get perfectly aligned pilot holes.
> > Bradley, you stooge!  You are a freakin' genius.  Since you are going
to
> > all the trouble, how about counting how many list members would like to
> > have one of those templates and getting a quantity break for
> > yourself too.
> > I would buy one.
> > Larry H
> Get a NextCard Visa, in 30 seconds!
> 1. Fill in the brief application
> 2. Receive approval decision within 30 seconds
> 3. Get rates as low as 2.9% Intro or 9.9% Fixed APR
> Apply NOW!
> http://click.egroups.com/1/2646/3/_/529958/_/955035823/
