Vinyl lettering
2000-04-12 by David Bivins
I have been discussing screen-printing with another member of this list, as I have a very good connection. We will share our findings soon, I hope. Anyway, my connection also has a vinyl sign cutter which is what you've been describing for applying logos, etc. I don't think it's designed for very small work, but I could be wrong. As described by others, it is essentially a plotter with a blade rather than a pen. It uses rolls of vinyl that either have adhesive on the front (if you're doing a shop window, e.g. and want the vinyl inside) or back. You peel away that which you don't want (the in-between bits) and then apply the vinyl, already spaced perfectly as it still has the backing (which is not cut). Did that make sense? If anyone has specific ideas for what they would want, let me know. David. http://www.mp3.com/baldbastard http://www.mp3.com/stations/baldbastard ___________________________________________ "[A] synthesizer can be connected to a computer. This means that the musician can play his instrument long before a concert, because the computer can play the instrument again at the right time... The musician can sit in the audience and listen to the concert. He can even be hundreds of miles away, eating dinner or taking a nap." - Funk & Wagnalls Young Students Encyclopedia 1973
