MOTM
Mother of All Bandpass?
1999-05-14 by Paul Schreiber
The current design of the '410 filter has the LFO ouputs running "in
parallel" to all
three filters. They are equally summed, so there is a MASTER depth, but no
individual DEPTH. All filters move the same amount (they just have different
center freqs).
PROPOSAL (this will make Dave happy!)
Go to a 3U wide.
Replace the LFO DEPTH pot with 3 individual DEPTH pots.
Add 3 LEDs. The LEDs are analog. The brighter they glow, the higher that
associated bandpass filter frequency is (no bitching if this seems
"backwards". )
The LEDs would pulsate at that filter's LFO rate. (in German: "Das Lites
gablinky!")
Add LFO OUT jack for other module fun.
Added kit cost $30-$40. We are now in the $229 kit arena.
Another way: 3 slightly different summing resitotors (narrow, mediium, wide
sweep). Free.
Well?
Paul S.
Re: Mother of All Bandpass?
1999-05-14 by J. Larry Hendry
Hell, its modular.  Load it up and go for the extra features.  However, I
would buy either one (since it will be 2 years into the MOTM expereince
since I know anything anyhow). <g>
BTW, I finally got started on the oscillators.  I am building both at the
same time, so I am still in the resistor stage.  Based on available time
and rate of progress, I will be middle of next week I suspect (unless I
just totally ignore the 10" tall grass).
Where was that resistor print error in the instructions?  I have not found
it yet.
Larry H.
> From: Paul Schreiber <synth1@...>
> To: MOTM listserv <motm@onelist.com>
> Subject: [motm] Mother of All Bandpass?
> Date: Thursday, May 13, 1999 11:59 PM
> From: "Paul Schreiber" <synth1@...>
> parallel" to all
no
different
> center freqs).
> Go to a 3U wide.
> "backwards". )
> gablinky!")
wide
> sweep). Free.
> Well?
> Paul S.
1999-05-14 by Dave Bradley
> parallel" to all
> have different
> center freqs).
> Go to a 3U wide.
> "backwards". )
> gablinky!")
Definitely!
Hmmm, I thought we already added this. Remember, to get synchronized stereo
panning externally, this jack is required. It's already on the mocked up
image, anyway!
That's a bargain for 3 more pots and lights.
> mediium, wide
> sweep). Free.
I could go with this option also, I just want the gablinky lights!
Dave Bradley
Principal Software Engineer
Engineering Animation, Inc.
daveb@...
1999-05-14 by David Bivins
> Go to a 3U wide.
> "backwards". )
> gablinky!")
Yes! I would by this over the previous proposal.
1999-05-14 by Mark T
I'll vote for the 3 space 410 unit also.
I like the additional control options, and, of course the LED's.
Hows about a rotary switch for the "single/dual/dual-rev" switch.  It may
balance out the real estate.
Blink away brothers!
Mark Tencza
1999-05-14 by Hugo Haesaert
Hi Paul n All !
Go for 3u, add 3 jacks that break each lfo->depth control .  Since
the lfo has an out, combining this with an envelope and reinjecting
it could be fun .  Without global FM in this would make fixed
bandpass possible, giving a triple resonator :)
Also add resonance CV jack and depth control, not original, but hey
(if technically possible :) )
Bye .
Keep 'em oscilating :)
Hugo
