Re: [motm] Thanks Larry for the great idea...
2000-05-03 by J. Larry Hendry
> From: Nathan Hunsicker <nate@...> > To: motm@egroups.com > Do you think Paul would ever consider making such > a panel? It could probably be made from a single > piece of 1/8" aluminum (8.75"x19.25") with a 7"x17.5" > opening cut and bent back 90 degrees to form a simple > support for the rackmount stuff. No, I doubt Paul ever would. Yes, you are grasping the concept as I had imagined. I had not thought about the bending back though. I thing it would be cheaper not to do this. You have uncovered the two main issues: 1 Strength 2 Flushness of panels. I have not thought about it enough to have a full plan yet, but I think I would make it from pieces instead of a big sheet. I only say that because I envisioned the actual rack rails being recessed even with the mounting rails so that the rack faces were flush with the MOTM panel faces AND with the trip at the top and bottom. But, you have the concept and you can develop it to sit your own needs. Larry P.S. Yes, you are dreaming, but DON'T stop. :)
