Thank God!!!
2000-05-09 by Nathan Alan Hunsicker
I finished building my 410 today. After replacing that pesky TL074 op amp I put in backwards, I was ready to power up the module and test it. When I connected it to the power supply and turned it on, everything stopped working, the light on my LFO was showing a dim green and was not oscillating. Of course I immediately turned the PS off and disconnected the 410, powered back up and everything works fine. Now I'm thinking something is shorted out so I take one last look at EVERYTHING, not one thing wrong (except for a resistor not facing the same way as the others.) my next thought was does my PS have enough power to run all my modules? I only have a 300, 320, 110, 120, 420, 410 & three 800's, it couldn't possibly be the PS, but just in case, I disconnect one of the 800's and try again, SUCCESS!!! So now I'm thinking I need another PS as I prepare the module to put in my rack, I plug it back in, bolt it to the rack rails, power up and WHAMMO, it happens again. I'm totally lost, just as a last resort I try switching the MTA cable to the one that was powering the 800 and it works! For some reason, when the bad MTA cable is not connected to a module, it is fine, but as soon as I connect it to a module (any module) it shorts out. I am so glad that it was the cable and not my module. NOW, what was the reason I typed all of this you ask? Just in case you build a module and can't figure out why it doesn't work, don't forget the obvious, test the power cable. -Nate
