Re: [motm] Cabinet Update
2000-05-30 by Paul Schreiber
Well, I see a possible problem :( The flat rails are the same width (0.500") as the MOTM-19As. What you did is "cheat": you laid the rails over the front, which "subtracted" the metal thickness plus about 50mils of the bend radius. So, what will happen is that the wood will not be entirely behind the flat rails, there will be a portion "sticking out in the wind" without any wood behind it. Then, since the holes for attaching the flat rails to the wood are in the centerlines (at 0.250") you have only 1/8" 'left over' to insert a wood screw. It can be done, but *be exta special careful* not to split your support. Paul S. yep, I have returned ----- Original Message ----- From: alt-mode <alt_mode@...> To: <motm@egroups.com> Sent: Monday, May 29, 2000 7:55 PM Subject: [motm] Cabinet Update > ... A quiet weekend, I guess everyone is enjoying either the barbeque or their > modulars ;)... > > I took a few modules and a pair of 19A rails over to my woodworker friend's shop. > He has been working on a Moog-style upper cabinet for my MOTM modules. The cabinet > is 5U high and 27U wide. Since the flat rails are not available, I needed to do > some test fitting with the 19A rails. If the measurements are the same, as Paul has > alleged, then I think this is going to work out very well! We used 3/4" birch, and > made a lip on the front edge that is 3/8" wide. The rail fits nicely over this lip > wtih some overhang. There should be enough wood to screw the rails into the lip. > He created the lip with a router and will have to chisel out the edges since the > router can cut a 90 degree corner at the ends. > > I had given him a 2U blank panel along with a drawing of the cabinet several weeks > back. > > My friend was a bit concerned about the strength of the back of the cabinet so he is > adding a 2" wide brace from the top to the bottom on the rear and is cutting two > holes in the brace to hold the power socket and fuse along with the power switch. > I'm disassembling a MOTM-900 supply to use in the cabinet. > > When he's finished gluing it all together, I get it for final sanding and staining. > I'll try to send some pics as it comes together. I hope the flat rails happen > fairly soon or I'll be using wood screws to hold the modules in the cabinet!
> > Eric > > > __________________________________________________ > Do You Yahoo!? > Kick off your party with Yahoo! Invites. > http://invites.yahoo.com/ > > ------------------------------------------------------------------------ > Best friends, most artistic, class clown Find 'em here: > http://click.egroups.com/1/4054/5/_/529958/_/959648147/ > ------------------------------------------------------------------------ > >
