Re: [motm] MOTM DarkStar
2000-06-07 by J. Larry Hendry
> Hello all. I received my Blacet DarkStar kit the > other day. I was wondering how people are > mounting this to MOTM panels. I am assuming > everyone is using off board pots. Any help is greatly > appreciated. thanks, Charles. Charles, I am not getting a Dark Star, but the Blacet circuit board pot spacing really requires off-board pots if you want to stay with the MOTM standard pot spacing. You could get "close" by board mounting every other one and then off board for the in-betweeners. However, I found the Blacet board-mount pot shafts just a little too short in the "threads" to go through the thicker MOTM panels. I used a MOTM style bracket on both of my Blacet-2-MOTM conversions and positioned it on the front so as to run the circuit board in the middle as opposed to one side or the other. This seemed to work best for me and I was able to make it so that the holes for mounting the bracket did not interfere with pots of other front panel graphics. I had to find places in the Blacet PC board to (carefully) drill mounting holes that didn't interfere with anything else. On the pots that went to the "upper side," I soldered the wires to the PC board normally. On the ones that went to the bottom side, I soldered the wires leaving the circuit board from the opposite side (easy on nice double sided boards). I passed them through the bracket with grommets and soldered them to the pots. See attached photo of by Blacet FD. I have several photos of this thing I can send privately (as to not clog up the list with big files). But, here is one that answers your question and may be of general interest. Normally, I use a nut on the back of the pots (recent list discussion). But, these are the plastic threaded ones that really cannot be overtightened (so I have only a spacer). I'll probably go back and add the nuts though since I finally found a source. Larry Hendry
