USER TIP
2000-06-22 by J. Larry Hendry
From: David Bivins <dbivins@...> > I just had a brain flash about MOTM-700 routers! Me too David. Want to creates some neat patterns? Try this: --------- Keyboard CV into all of your oscillators. Tune them all in unison. Take a 700 switch pair. Connect a bias voltage to one input on each switch. (you can use a 800 for this). Connect one output on each switch to the FM input of two separate 300s. Using the 700 panel knob to switch the bias voltage on and off, tune the bias to produce an interesting interval tuning (like a 3rd, 5th, 7th, whatever. Tuning will be accomplished with the amount of bias voltage and the amount of FM on the VCO. Hook 320 LFOs up to control the 700 switches. Now, the LFO rate will control the oscillators switching in and out of unison to some interesting interval while you play happily from the keyboard. Have fun. Stooge Larry
