RE: [motm] OT: ribbon controller instructions (was: RE: I pity yo u fellow motms)
2000-07-11 by Tkacs, Ken
I can give you a couple of hints. Scan big, like you have. Then bring the image into photo editing software (Photoshop is best). Here you can 'de-skew' the image to make it perpendicular to the screen edges. Most important, play with and raise the contrast. This will eliminate the ghostly bleed through from the reverse side of the pages, as well as *tremendously* help your compression ratio. Photoshop's Histogram feature is worth its weight in gold for this kind of tweaking. Lastly, never use JPeG compression on anything other than color photographic images. JPeG is wasted on monochrome photos, and very detrimental to high-contrast graphic images. For type, schematics, etc., use GIF compression. Choosy moms always choose GIF. Even if you want to reduce the image size, do that last. Scan big, fiddle with contrast, etc., and lastly reduce to final size (hopefully a simple ratio to the original, such as 1/2, 1/4, etc. Hope this helps.
-----Original Message----- From: skinny bastard [mailto:skin_job@...] Sent: Monday, 10 July, 2000 8:37 PM To: motm@egroups.com Subject: [motm] OT: ribbon controller instructions (was: RE: I pity you fellow motms) Sorry about the scans being so big..... trying to get used to using a scanner.
