MOTM
silly string...
silly string...
2000-07-16 by sikorsky
hello all,
i know this is off topic ;-)
but, i thought the list needed a good old gear shot - so here we go
i spent the entire weekend finishing off a load of non motm modules, and
with any luck my red cross box from texas will arrive at the end of next
week..? - good job i finally got the second cabinet assembled
top to bottom l to r:
diy inverter & lag processor (off the net somewhere), oakley (tony allgood)
wavefolder, motm 120, 410, 420, 440
motm 320, oakley lfo, motm 300, oakley multimix, 2 x motm 800, motm 110
oakley midi/cv convertor, motm 100, 700, diy chaos generator, diy 4520 clock
divider, mults, ties etc
right hand cabinet, the runt of the litter, oakley eg & vca combined in one
unit - i ought to explain that it's sat there for two reasons, 1: i broke my
test supply so i couldn't check my ropey wiring, 2: i need to butcher the
panel to make it fit (oops)
so when it's finished, it's my lazy vca...   ...also, if you look carefully,
on top of the left hand cabinet you can see my little black patch book, and
at the bottom right (pure coincidence) there's a beermat from a local band
from years ago called "the wealthy texans" heh heh...
anyway, my final comment - i got a slightly nackered Jennings Univox the
other day - a quick modification, and it sounds absolutely stunning through
the motm filters (and the wavefolder tony), otherwise it sounds like a very
poorly stylophone
but it looks drop dead sexy...
cheers all
paul b
(my cats like string too...)
