MOTM
RE: [motm] "micro-hocketing" and MOTM-700
2000-07-20 by Dave Bradley
Hmmm. What you really want is to control the timbre by phrase, not by
individual note. You need to run a separate synchronized sequencer to
control the switching of the 700s independent of the sequence note events.
Send your 700s and 300s to me instead of Bivins.
Dave Bradley
Principal Software Engineer
Engineering Animation, Inc.
daveb@...
> From: David Bivins [mailto:dbivins@...]
> Sent: Thursday, July 20, 2000 1:24 PM
> To: MOTM
> Subject: [motm] "micro-hocketing" and MOTM-700
> So get a bunch of MOTM-700s and a CV sequencer (sequencer with voltage
> output).
> Run the sequence into the first 700, set the threshold in the middle so
> you're doing the equivalent of a "split point" for note values.
> Run output 1
> into a second 700, output 2 into a third 700.
> Keep doing this until you've divided all of your pitch values so that they
> get a separate output. Run these outputs into separate oscillator/modifier
> combos.
> Now you've taken a simple serial sequence and given each pitch
> value its own
> timbre.
> If you don't understand what I'm talking about, send me all of your
> MOTM-700s and MOTM-300s and I'll demonstrate. I'll need a lot, so everyone
> should ship them to me as soon as possible ;)
> David.
> Failed tests, classes skipped, forgotten locker combinations.
> Remember the good 'ol days
> http://click.egroups.com/1/7076/6/_/529958/_/964110262/
Pay no attention to that man behind the curtain!
Moe
> Sent: Thursday, July 20, 2000 2:49 PM
> To: motm@egroups.com
> Subject: RE: [motm] "micro-hocketing" and MOTM-700
> Well, that's why I made up the term "micro-hocketing" because I really do
> want to do it by note, not phrase. I don't have a word for it.
> So because Bradley misunderstood me, it is twice as important
> that you send
> the 700s and 300s to me, David Bivins.
> Bradley's "old school" hocketing must be prevented at all costs.
> David.
2000-07-20 by David Bivins
output).
you're doing the equivalent of a "split point" for note values. Run output 1
combos.
Now you've taken a simple serial sequence and given each pitch value its own
timbre.
David.
Re: [motm] "micro-hocketing" and MOTM-700
2000-07-20 by improv@peak.org
It seems like you could do something similar with a like,16 channel
VC-switch: it'd have 1 CV input and 16 outputs, and a gate input that on
each step of the sequencer, advances the output by one step. Does anyone
make something like this?
(if so, you can send ME all the 700's, since you won't be needing 'em ;-)
>output).
>combos.
>timbre.
>David.
____________________________________________
Dave Trenkel : improv@...
Minus Web Site: http://listen.to/minusmusic
Minus MP3's: http://www.mp3.com/-minus-
So because Bradley misunderstood me, it is twice as important that you send
David.
> From: Dave Bradley [mailto:daveb@...]
> Sent: Thursday, July 20, 2000 11:21 AM
> Dave Bradley
> daveb@...
> > To: MOTM
> > output).
> > Run output 1
> so that they
> oscillator/modifier
> > combos.
> > value its own
> > timbre.
> so everyone
> > David.
> Remember four years of good friends, bad clothes, explosive chemistry
> experiments.
> http://click.egroups.com/1/7077/6/_/529958/_/964113707/
