RE: [motm] FW: [AH] Frequency doubling for VCOs
2000-07-28 by Tkacs, Ken
You can also use phase-locked loops. The number of serial flip-flops you put in the loop determines the number of octaves shifted.
-----Original Message----- From: Dave Bradley [mailto:daveb@...] Sent: Friday, 28 July, 2000 4:21 PM To: MOTM List Subject: [motm] FW: [AH] Frequency doubling for VCOs (Amazing - a nice programming trick amidst the dreck that is usual to AH - Moe) Frequency Doubling for VCOs Here's an idea to create a sound one octave above the normal pitch. Maybe it will help us focus on analog stuff... We all know you can get sub-octaves by putting flip-flops after the VCO output. One pulse sets the FF output to high, the next pulse switches the output to low, and so on. You cannot use this technique to get higher than original sounds simply because you don't know when the next pulse is due. Or do you? If you take an ascending (for now) sawtooth, you can use a CPR (comparator) module to get a square wave. The second half of the wave will yield a positive output. If you invert that pulse-out, and add it to a the sawtooth output (after the CPR), you get two rising ramps for every VCO cycle. If you adjust the levels so that these two ramps are identical, you have created a sawtooth wave one octave above the VCO's pitch. Better still: If you still have modules to spare you can repeat this trick for more octaves!
