Re: [motm] 700 modulations
2000-07-30 by J. Larry Hendry
I have a little 5 sec mpeg file of this effect showing the scope and hearing the wave if anyone would like to see what Tomy's idea produces. I added the audio in a modulation. Very cool. The file is about 200K. I thought maybe a bit big to post to the list. Larry H ------------- Tomy wrote: Just toying with waveform mangling. With a ramp into both the CV and A inputs on a 700, and -5 into the B input, I get a waveform whose positive is ramp and negative is square or pulse. And it is an octave higher. Very similar to a recent discussion on synth-diy. Of course, now I want VC of the switch threshold on the 700. ----------- LH responds: OK, I just tried this. Cool. However, I did not get the octave up thing. Try this with +5 volts. MUCH more interesting in my opinion. BTW, my suggestion for mixing another CV with your CV-IN of the 700 works to control the threshold just as I thought. Now, use the follow inputs to that mix: 1 - LFO - gives you LFO speed PWM of your saw/pulse wave 2 - EG - gives you a wave that migrates over time. 3 - Audio from another VCO (higher freq) - S**T this is wicked. You get the audio of the second oscillator appearing on the other wave just at the edge of the pulse, almost in a carrier like fashion. Sweep it and it is kind of like hard sync, but not.
