RE: [motm] Im new: Hello
2000-08-05 by Tentochi
My suggestion would be to bypass the '120 for now and add an '800 EG and a VCF--probably the most versatile is the '440 which is an MS-20 filter with lots more flexibility. Also, make sure you have some way to control everything. MIDI keyboard and MIDI to CV convertor, analog keyboard or an analog sequencer. There are other possiblities too. Paul usually recommends the Kenton MIDI-CV convertors; most of the people on the list tend to have or favor the Encore Expressionist. I didn't catch whether you already have equipment or not. So make sure you have some way to hear the beautiful sounds (even if your wife or girlfriend or other doesn't agree with that assessment, we do) you are making. Usually a mixer, amp and speaker combo although there are simpler ways to go. The MOTM is designed to fit exceptionally well in an SKB pop-up mixer case. Several of us on the list have these and they work very well especially if you like to drag your equipment around. Also make sure you have lots of 1/4" patch cables. Unfortunately Paul does not sell these at this time. Wacky Kovacky (sp?) cables seem to be popular here among others. You didn't say whether your are getting kits or assembled units. If you are going the kit route and don't have tools already, it is well worth following Paul's suggestions for what tools to buy. You will also need mounting rails which I am sure Paul won't let you forget. This may seem like a lot, but remember most of these are one-time purchases. If you are a seasoned electronic musician and DIYer, pass over these comments and pass them on to all of the newbies who have just seen the MOTM/EM light! Amen! Shemp P.S. I am not the real Slim Shadey...
> P.s. Paul has recommended the following system to satrt with any > additional > recomendations ? > 1ea MOTM-900 Power Supply > 1ea MOTM-300 VCO > 1ea MOTM-320 VC LFO > 1ea MOTM-120 Sub-Octave Mux > 1ea MOTM-110 VCA/Ring Mod (mostly for the Ring Mod part)
