Re: [motm] Future Sequencer PSU
2000-08-07 by J. Larry Hendry
Paul, Can you be a little more specific in your recommendation. Do you mean on the AC side only or on the DC side of the supply. It seems to that the AC case ground is completely isolated from the DC side ground. Of course, if properly wired, all the cases should be common at ground. I was considering making the DC ground common at the PS as well. Is that what you mean? Thanks, Larry H ----- Original Message ----- From: Paul Schreiber <synth1@...> In general, multiple supplies need to have a common ground *only* at the supplies. The 3-output Power Ones are connected on the little pcb in the supply itself.
