FW: [AH] MOTM 300 VCO mini review
2000-08-12 by Tentochi
Sorry to those of you already subscribed to AH. --Shemp
-----Original Message----- From: norman fay [mailto:nfay@...] Sent: Saturday, August 12, 2000 9:06 AM To: analogue@... Subject: [AH] MOTM 300 VCO mini review Having finished building my two latest purchases, I thought I'd post this (440 VCF review to follow) ***General stuff about MOTM modules*** All of the MOTM modules I've built so far have the following characteristics: -Extremely sturdy construction - the circuit board is bolted onto a metal plate, which is then bolted onto the front panel. This front panel is extremely thick and strong. -Smart appearance with easy-to-read graphics. Doesn't look as cool as modcan or wiard, but it still looks good. -Good-quality connectors and pots -Extremely easy to follow instructions -which combined with- -Well-packaged and labelled components means that as long as you follow the instructions, solder neatly, and *do as yr told* you will certainly get a fully working module for your labours. As an aside, personally speaking, I don't really enjoy soldering stuff together. I do enough of that at work, and I'd much rather play with this stuff. However, I'm glad that MOTM and Blacet electronics provide their modules in kit form, because it means that I save money, which I can spend on more modules... The other good general thing about MOTM modules is that they are nicely laid out, with the sockets in two rows across the bottom of the panel. The sockets are big chunky 1/4" jacks - I prefer 4mm banana sockets myself, because you don't need multiples, but you do get some handy switching functions with the jacks, so I resisted the temptation to replace them with bananas... One downside of the size of the modules is that you'll need a lot of wallspace even for a medium-sized system. An SKB pop-up case will take only two rows of modules. ***Specific to the MOTM 300 VCO*** building it. This kit features a lot of components packed into a very small space. In order to sucessfully build it you need to be able to solder very neatly. One of the components in particular - a small double transistor - has TINY solder pads. I can solder neatly, but I still managed to blob two of these pads together, so I had to use my solder sucker, and do it again. MOTM recommend that beginners do not attempt this module, but I'd say, having built two, that *if* you can solder neatly, and are EXTREMELY careful abt following the instructions, you can probably manage it. I wouldn't recommend it though. The worst bit is soldering leads from the circuit board onto the 9 front panel sockets, three switches and two pots (the other 4 pots are circuit board mounted). For some reason this is just extremely tiresome. I'd estimate that it took me abt 8 hrs to complete my VCO. Once you get into the rhythm of soldering all those little bits in, you'll find that hours just melt away. Despite all of the moans above, there is a real sens of achievement when you plug the thing in and it works. This is the *best* bit, and it makes all the other stuff worthwhile. using it. This is a very well specified VCO. The tuning is very stable, and it warms up quickly. The waveforms are nice and bright, so there's plenty for filters to work on. one of the two modulation inputs has switchable ac/dc coupling and linear/exponential scaling. Soft and hard sync are available, and you get PWM with two controls (initial width and mod depth) The few things it will not do are variable depth sync (like on EMS), and other variable waveforms, like on EMS, Serge and my Rhodes Chroma. This is all pretty esoteric though, and I imagine that a waveshaper module would cover the variable waveforms anyway. I used the VCO with Serge, Blacet and Modcan modules, and it worked fine with everything except the Serge and Modcan waveshapers, which produced unpredicable, but still useable results. Something to do with polarity and DC coupling I think (the voice of ignorance speaks) Bottom line is that this is a stable, well engineered VCO that, while it costs some more $$ is worth it because of the clever design and the high-quality parts. If you buy one, I'm sure that like me, you won't be disappointed For the record, I have no connection with MOTM or paul schreiber other than that of being a customer, and I'm getting no kickbacks or any of that shit for this. I'm just trying to be informative... Next - MOTM 440 VCF Coming soon: modcan VCO and "Moog-style" VCF Wiard dual filter best wishes -- norman fay
