MOTM
button, no button?
button, no button?
2000-08-23 by thomas white
I was thinking of a momentary switch just to trigger on cycle from the front
panel so you could check the env generators shape by itself instead of
hitting it from the controller and most likely firing every other env gen in
your system at the same time. Similar to the one on my Blacet Final Filtre.
Just a thought and would, for me, make things easier in my way of setting up
and examining patches.
TW
>From: "Tony Karavidas" <tony@...>
>Reply-To: motm@egroups.com
>To: <motm@egroups.com>
>Subject: RE: [motm] 3rd version panel layout
>Date: Tue, 22 Aug 2000 18:56:17 -0700
>Well, the panel trigger is possible, but I'm not sure if it's worth it. If
>you add a switch dedicated to trigger this module, it would be nice if you
>had a jack to use it to trigger other things. You can see how things get
>out
>of control. Should it be a pushbutton, a momentary level, something else?
>I'll still think about it. If "everyone" said they wouldn't buy it UNLESS
>it
>has a trigger switch then obviously it would be added.
>Thanks for your input. (and everyone else too)
>Tony
> > From: thomas white [mailto:djthomaswhite@...]
> > Sent: Tuesday, August 22, 2000 6:08 PM
> > Subject: [motm] 3rd version panel layout
> > The best one so far especially with the added sequencer
> > functions! I still
> > vote for the small knobs due to saving space. I guess I could
> > look at the 4
> > space panel now with the sequencer functions, but the cost would
> > have to be
> > insane!!! I much prefer the 2-space version to save space in my
>expanding
> > synth rack.
> > Thomas White
> > PS. What about the panel trigger? Possible or no?
________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com
