Re: [motm] MOTM and SQ-10
2000-09-09 by sikorsky
> Anybody use a MOTM with a Korg SQ-10 and find any issues/problems? hello all, isn't that the one that was designed for the MS series..? so it'll be inverse gate & Hz /V then..? cheers paul
2000-09-09 by alt-mode
--- sikorsky <vulture.squadron@...> wrote: > > Anybody use a MOTM with a Korg SQ-10 and find any issues/problems? > > hello all, > > isn't that the one that was designed for the MS series..? > so it'll be inverse gate & Hz /V then..? > Yup, the SQ-10 is designed to go with the MS-10/20/50 and they all use Hz/V but it is just a series of knobs with no real scaling so you could probably get away with using it since you would have to tune for every knob. The range on the knobs might seem a bit wacky going into a V/Oct MOTM system. I don't believe it has any quantization but I may be wrong. Eric __________________________________________________ Do You Yahoo!? Yahoo! Mail - Free email you can access from anywhere! http://mail.yahoo.com/
2000-09-09 by jhaible
> > > Anybody use a MOTM with a Korg SQ-10 and find any issues/problems? > > > > hello all, > > > > isn't that the one that was designed for the MS series..? > > so it'll be inverse gate & Hz /V then..? > > > > Yup, the SQ-10 is designed to go with the MS-10/20/50 and they all use Hz/V but it > is just a series of knobs with no real scaling so you could probably get away with > using it since you would have to tune for every knob. The range on the knobs might > seem a bit wacky going into a V/Oct MOTM system. I don't believe it has any > quantization but I may be wrong. I found the SQ-10 being problematic, but not specifically with V/Oct gear like MOTM. Yes, it does work with V/Oct (What you need is a gate inverter for the Gate signals, though), and the range switches help setting the desired sensitivity of the knobs. But ... IMO the SQ-10 is so badly designed from its user interface that you will think twice before you get one. (And I am generally very fond of Korg stuff, including the MS series, mind you.) Want to change the sequence length - no switch - you have to re-patch the whole thing. Do this on the fly while recording something - not. In theory you have the advantage of individual access for each step's gate output (and a reset input) - but keep in mind that all this is switch trigger as well. (MS-series users will appreciate that.) The rotary knob that selects the different sequencing modes isn't the best choice either. I don't remember what it was exactly - I think the currently running sequence is always reset when the mode is changed. Or something similar. The SQ-10 was something I badly wanted and bought at an auction, but which I soon sold again for less money, just to get rid of it. All right, no flames please, it's just my personal opinion (;->) In short: Problems yes, specific problems with V/Oct no, Gate inverter(s) required. JH.
