CS-50 as controller (was: Re: [motm] Yamaha CS-5/10/15 as MOTM controller)
2000-10-13 by jhaible@t-online.de
Following up my recent mail, here it is online: I finally started that insane project of building a polyphonic (4-voice) Modular System. The first Module is finished, an Interface Module to use the Yamaha CS-50 as a keyboard controller. If you want to take a look, schemos and front panel graphics are here: http://home.debitel.net/user/jhaible/additional_schemos.html At the moment there is just that, the interface. And a lot of ideas in my head. But I feel that actually building the first module was like crossing a boarder - no more easy going back now. (;->) Meanwhile, it's good to play the Minimoog clone from the CS-50 keyboard, doubling the bass note. And sweeping the MOTM Triple Resonant Filter with the CS-50's aftertouch ! JH. -----Urspr\ufffdngliche Nachricht----- Von: jh. <jhaible@...> An: <motm@egroups.com> Gesendet: Sonntag, 8. Oktober 2000 22:10 Betreff: Re: [motm] Yamaha CS-5/10/15 as MOTM controller > > > I think this came up a while back; do the old Yamaha CS mono synths have > > normal 1v/octave CV outputs and regular gate or trigger outs that are > > compatible with MOTM? > > I don't know if the CS monos had a V/Oct output (I doubt it). > But ... > > I am currently expanding my CS-50 to be the center of a 4-voice polyphonic > Modular synth. While the polyphonic CVs will be V/Hz (as inside the CS-50), > it will have two extra V/Oct outputs for driving monophonic V/Oct gear > (such as MOTM) as well. What you need is (basically) a logarithmic converter > which is a standard building block more or less, but to make it useful for > musical purposes, I have added some features like octave range switches, > single trigger / multi trigger logic etc. > And I'm also bringing out some of the CS-50 internal modulation signals > (PWM LFO, "SUB" LFO, and Ring Mod OSC) with the interface as well. > It's almost finished, and I hope I'll be able to publish the schematics in a
> few weeks. i don't know how close the monophonic CS synths are to the > CS-50, but I assume there are similarities. > > JH. > > > >
