MOTM
Is this useful?
Is this useful?
2000-10-15 by Paul Schreiber
On the VC Pulse Divider from Serge, there is an output called 'STEPPED'. I'm
am pretty sure
how they did it (not seeing the circuit).
The output is a stair-cased, positive-going sawtooth. The sawtooth is
generated by a 5-bit
counter, that is *clocked* by the input pulses and *reset* by the
divide-by-N pulse.
The output counter bits feed a 5-bit DAC.
So, here are some interesting things about this sawtooth:
a) for a fixed frequency in, the *amplitude* is inversly proportional to the
divide ratio. Think
about it: the longer you count, the higher the amplitude.
b) of course, for a fixed input frequency, the *output* frequency is
proportional to the divide
ratio. If you input 4Khz and divide by 8, you get out a 500Hz sawtooth with
8 steps. Assuming
a -5V to +5V output scaling (like all the other signal generators), we have
10V/32 steps = 312mv/step. So for 8 steps = -5V to -2.5V sawtooth.
For straining the brain more: this acts as a low-pass filter! Since the
divide ratio is a control
voltage, then if the input is fixed (say 2Khz) then as the divisor is swept
from 32 to 1 the
amplitude AND frequency change. But, the amplitude drops off at higher
frequency outputs
since the counter is reset faster and faster.
Of course, if you fix the divide ratio and sweep the input, the amplitude of
the sawtooth is *constant*
at the divide ratio X 312mv.
Will add $15 to the cost of the module. Discuss!
Paul S.
Re: [motm] Is this useful?
2000-10-15 by alt-mode
I see very little to discuss.  This is a very cool feature and well worth the $15.
At the very least, it is good to get some other waveform out of the pulse divider
than square wave!  Please add this feature.
Eric
> am pretty sure
> divide-by-N pulse.
> divide ratio. Think
> 8 steps. Assuming
> from 32 to 1 the
> frequency outputs
> Paul S.
Do You Yahoo!?
Yahoo! Messenger - Talk while you surf!  It's FREE.
http://im.yahoo.com/
2000-10-15 by jwbarlow@aol.com
I don't use this output very much, but when I do, I use it more often as a CV
source than a (audio) signal source. It's good for weird glissandi kinda
things -- I always thought the output was a whole tone scale (into a 1V/oct
input), but I never use it in a tempered music setting, just more atonal
stuff. I should point out that Serge used 0-5V signals, so the steps are half
what the MOTM would be.
I find this to be a nice feature when you want another varying voltage, and I
think it's well worth the $15. It is nice to have for those very electronic
"everything modulate everything else" patches.
JB
In a message dated 10/14/2000 7:24:20 PM, synth1@... writes:
>I'm
>am pretty sure
>divide-by-N pulse.
>the
>divide ratio. Think
>with
>8 steps. Assuming
>have
>from 32 to 1 the
>frequency outputs
>of
2000-10-15 by The Old Crow
  The VCPD already had the 4-bit RAMP output; are we talking about
changing that around a bit?  It could probably be done in the code.
Crow
2000-10-15 by jhaible@t-online.de
I'm
> am pretty sure
I thought I was pretty sure how they did it, too, but I may me wrong:
I thought they used a charge pump like that NS app note for the
LM3900. I mean they might have used a counter, but seeing Serge's
general fondness of the 3900, I'd be surprised if he would not have
done it with that single chip. (Anybody knows for sure ?)
And yes, bringing out the ramp would be useful. (I have not done it
on my version, but I wished I had.)
JH.
> divide-by-N pulse.
> divide ratio. Think
with
> 8 steps. Assuming
have
swept
> from 32 to 1 the
> frequency outputs
of
> Paul S.
2000-10-15 by davevosh@aol.com
In a message dated 00-10-14 22:24:18 EDT, you write:
<< Will add $15 to the cost of the module. Discuss!
paul,
just my 2 cents worth but i`d say "yes" include it.
best,
dave v.
2000-10-15 by weld
although I still dont know what Ill use this module for, Im all for adding as
many options, including led's : )  as possible./
Jim
> I'm
> > am pretty sure
> JH.
> > divide-by-N pulse.
> the
> > divide ratio. Think
> with
> > 8 steps. Assuming
> have
> swept
> > from 32 to 1 the
> > frequency outputs
> of
> > Paul S.
2000-10-15 by Dave Hylander
I'd say it's worth the $15.
dh
2000-10-15 by Jeffrey Pontius
Not that I'll change the consensus so far, but the more versatile the
module the better.  For $15 more, please add it.
2000-10-15 by J. Larry Hendry
I would personally be willing to pay $15 for something like this.
Larry H
2000-10-15 by Gur Milstein
Hi .
i think its a cool feture as it can save a LFO use as a arprigator,
by quantized the output in sync with the input clock you can
get wiled sequencing.
thanx
Gur Milstein
>am pretty sure
RE: [motm] Is this useful?
2000-10-16 by Dan Higdon
I studied the LM3900 app notes a year or two ago, and came to the same conclusion about the Serge pulse divider. I'm as sure as someone who has never seen the insides of a Serge module can be that it's using a purely analog LM3900 staircase generator to do the dividing. And part of me respects the pure-analog-ness of that solution. ;-)
- hdan
Sent: Sunday, October 15, 2000 4:23 AM
To: motm@...m
Subject: Re: [motm] Is this useful?
I'm
> am pretty sure
JH.
> divide-by-N pulse.
> divide ratio. Think
with
> 8 steps. Assuming
have
swept
> from 32 to 1 the
> frequency outputs
of
> Paul S.
-------------------------- eGroups Sponsor -------------------------~-~>
Dial 1-800-555-TELL -- You Won't Believe Your Ears!
For more details, click here:
http://click.egroups.com/1/9537/16/_/529958/_/971602019/
---------------------------------------------------------------------_->
2000-10-16 by Brousseau, Paul E (Paul)
As the old late-night talk show dialog would go...
"Heh heh heh... YES!!!  Heh heh heh..."
"That's some weird shtuff."
--PBr
> From:	Paul Schreiber [SMTP:synth1@...]
> Sent:	Saturday, October 14, 2000 7:32 PM
> To:	MOTM listserv
> Subject:	[motm] Is this useful?
> I'm
> am pretty sure
> divide-by-N pulse.
> the
> divide ratio. Think
> with
> 8 steps. Assuming
> have
> swept
> from 32 to 1 the
> frequency outputs
> of
2000-10-16 by jhaible@t-online.de
There is a chance that Serge started with a 3900 circuit and upgraded it
to something more involved later, of course.
My own pulse divider story goes like this: Read the Serge catalogue,
thought it was a cool feature, designed a mildly involved analogue
circuit with CMOS gates and opamps (also a charge pump design),
and discovered that National application note *later*.
BTW, I wonder how Serge's phaser looks like, just for the sake of
curiousity.
I've once built the circuit from his patent (also LM3900-based, big
surprise),
and the effect was very interesting but not quite what I expected from a
phaser.
As the Serge phaser has a reputation for being very clean (and what I built
from the patent disclosure is the very contrary), I'm sure he's added a lot
of extra circuitry, or has switched to a different concept later.
JH.
2000-10-16 by Fahl, Romeo
I once opened up some later Serge modules with the intention of reverse
engineering them.  Saw lots of CA3280s but no 3900s, though this was in one
of the VCFs.  Didn't get far with the project, since the modules were very
tightly packed onto small pcbs and it wasn't my system to destroy.
Sent: Monday, October 16, 2000 12:49 PM
To: motm@egroups.com
curiousity.
surprise),
phaser.
JH.
synth-diy server down ?
2000-10-17 by Hugo Haesaert
Hi All !
Subject says it all .
Down ?
Thanks .
Keep 'em oscillating :)
Hugo
