MOTM
STC rant ...LONG and OT
2000-12-03 by thomas white
Hi all,
just thinking about a new project at home and wanted to ask around about it.
Has anyone built a Paia provided Electronics Projects For Musicians (EPFM)
Super Tone Control Before?
This is a Craig Anderton design from the late 70's based around a quad
op-amp in a design that is actually a filter (12dB I think) Anyway, I have
an old one of these from my EPFM days complete with rosin-core solder still
on the board, YIKES! It makes a cool textured filter sound, but has no CV
inputs...stock anyway. I was reading the project notes for this and
discovered that it can be modified with 2 resistors and caps changed to work
with 10v peak to peak voltages. Perfect with MOTM. My next problem in
adapting it was the CV inputs.
So I got my old Super Tone Control (STC) out of its Frac-Rak and started
with the voltage testing. I found that the frequency with no CV inout jack
was reading 0-5v response. I figure I can patch a cv right in place of this
pot and whammo, I will have at least a dirty CV input of sorts. Wait
though... upon further reading, I discovered that you can also get the
envelope follower kit from the EPFM book and hard wire it up to the STC.
This of course allows the filter to be controlled by the audio signal at the
input. I read the description of the schematic and the input circuitry
converts the audio to 0-5v DC as expected to control the frequency of the
STC. I should be able to feed a CV into the EF socket as well and use it a
CV input for the frequency. I will also be able to control the sensitivity
and sweep range of this CV due to the controls on the EF.
Another mod I want to make is to have individual outputs for the three
filter responses. This filter has High, Band and Lowpass sections with an
attenutaor for each one feeding a summing mixer for the output. I want to
split each signal out to a duplicate circuit of the output on the STC to
buffer and amplify each filter response. Now the STC will have a Mix out
with attenuators for each response and individual outs for other uses.
Unfortunately the STC filter does NOT self-oscillate. :~( Sad time, but
there is a resonance boost switch in the circuit that gives an almost
shell-resonance type effect to your sounds. I always use this to my benefit
with my old STC to make percussion samples.
I plan to mount this thing into a 3-space MOTM panel with full pot upgrade
and components replacement for the long run in as many places as possible.
Where do you get the shielded wire Paul? Part-number? I want the exact same
if you can dig it. I know this is knid of off topic, but you guys are the
first guys I have to ask in this situation. Thanks to Paul for the MOTM
format inspiration and teaching me to use better components (My old Paia
stuff iscratchy all over at 2 years old...Yikes)
Thomas White
PS. I guess the stuff from Paia runs about $60 total for the basic component
kits or you can get pcb alone. Ciao'
_____________________________________________________________________________________
Get more from the Web.  FREE MSN Explorer download : http://explorer.msn.com
Re: [motm] STC rant ...LONG and OT
2000-12-03 by improv@peak.org
>Hi all,
I have an STC built into a Rat-Shack box that I use as a stand-alone
processor, I run my Nord Micro and Groovebox through it often. It is a cool
sounding filter. I've thought about doing what you're talking about a few
times, but never gotten as far as you have. When/if you build it, let me
know how you do it,I'd like to try it myself.
Dave Trenkel : improv@...
Minus Web Site: http://listen.to/minusmusic
Minus MP3's: http://www.mp3.com/-minus-
2000-12-03 by ixqy@aol.com
I just got through last week ordering new pots for my Craig Anderton ring
mod. Now I'm thinking, how do I change this to work with the MOTM audio
in/out levels?
 I'd also like to do another mod... This ring mod only has one audio input.
The other signal that modulates the input is the onboard carrier osc. which
is set by a pot. This means that it's usually a static setting unless you
tweak the pot as you play.
 I'd like to mod it to have CV control over the carrier freq. but have no
idea how to go about it. Would I have to use a OTA for this or just patch in
a CV through a resistor directly to where the pot is connected? This IC used
is a 565 pll.
 Andrew Sanchez
In a message dated 12/3/00 1:53:34 PM Central Standard Time,
djthomaswhite@... writes:
it.
still
work
this
benefit
same
>  Thomas White
2000-12-04 by Paul Schreiber
The cable is called RG-174. You can get it at places like Allied or Newark.
It does take a little
practice stripping it.
Paul S.
2000-12-04 by J. Larry Hendry
I have had great success tapping the vast experience of the guys on
synth-diy on topics outside my simple reach.  The best list going on the net
IMHO (even if I cannot understand much of it).  :)
Larry H
To: <motm@egroups.com>
Sent: Sunday, December 03, 2000 3:58 PM
Subject: Re: [motm] STC rant ...LONG and OT
in/out levels?
is a 565 pll.
 Andrew Sanchez
