MOTM
FW: [motm] Connector survey
2000-12-17 by Tkacs, Ken
18 is a good number. 20's even better!
To: MOTM listserv
Sent: 12/16/2000 10:34 PM
Subject: [motm] Connector survey
I am designing a larger power jumper pc board with:
2ea 3-position screw terminal blocks (INcoming and OUTgoing)
some number of MTA-156 connectors
So the question is, how many MTAs? 16? 20? These are for "big ass
cases". I
am
thinking maybe 18 is a good number.
You can always add another one in the case. That's the reason for the
OUTgoing terminal. You
use 3 wires and connect to the second pcb's INcoming terminal.
Paul S.
