New MOTM format brackets? MUST read for 822 and 831 builders
2001-01-05 by J. Larry Hendry
OK. You have that hot new DIY project or 3rd party conversion module going to a MOTM format. Moe Bradley has made some super looking panels. Maybe you were one of the people that purchased some of the 70 sold of my 822 and 831 PCBs. You look at the back of the panels and think, "Where the hell is that stud to attach the bracket?" Well, now you know, if you didn't before that the blank panels purchased from Paul do not come equipped with studs. You could drill holes in the panel front and mount up the standard issue MOTM bracket. Or, you could check out http://www.modglin.com/larry and see what this stooge has been up to. If you have a 822 or 831 PCB you NEED to check this out. Whether this becomes reality or not is up to you all. Stooge Larry
