320 LFO as audio oscillator
2001-01-08 by J. Larry Hendry
> ----- Original Message ----- > From: Tkacs, Ken <ken.tkacs@...> > I might mention that the LFO is stable enough > to be a low-audio VCO...maybe you did and > it got cut off. Noe Schitt-Sherlock (as Jack said to his sister Noe right after her wedding to Steve Sherlock) This is one of my favorite uses for the 320 LFO. I think of it as that sub oscillator when a square wave just won't do. Hook it up right with your VCOs 1 volt/oct keyboard CV. Either sync it to your lowest tuned VCO or use a pulse divider off of one of your VCOs to get the sub oscillator frequency you desire and use that to sync your 320. Sync is necessary as the 320 was not designed to be a perfect 1-volt-oct trackable VCO. But, it is close enough to track well when sync'ed. The if you realy want some fun, use another 320 LFO output into the audio range 320 shape control. Now you have PWM on your sub oscillator - not just on pulse, but on saw and sine as well. Larry Hendry
