MOTM
This is an old one...
2001-01-19 by Dave Fulton
Aside from using Pauls Multi-Banana-1/8 adaptor module has anyone just
used banana jacks on there MOTM panels. I need to mod a users modules
for easier interface with his Serge panels. He has one of each MOTM
filter and one ADSR. Anything I should know before I suggest that I
perform this hack? And who sells the adaptors that allow banana's to
fit in the MOTM jack holes?
Dave
cases
2001-01-19 by Cap'n F.M. Bleep
hi dave...
i've got a motm that's about to outgrow its skb case (especially when i
get the time machine in there... the pcb is too long), and i'd like to
build one of your cases. i'd like to build it myself cuz it would bring me
closer to the machine and because i'd need to mod it a bit... i plan to
install my mobius in the bottom half, which means i'd need to bring midi
and power out to a panel on the back. i may eventually build a second
case, with an analog seq instead of a mobius (may have to change
dimensions).
do you you sell the plans or just the cases? and if you just sell the
cases, would you be willing to accomodate the mods i'd need to do to get
the sequencers in there? it would probably be a few months before i do
this, so i'm just exploring the possibilities...
thanks dave!
fred.
bleep.
out.
Re: [motm] cases
heh... whoops! that was supposed to go to dave fulton, not the list. argh.
these computer things are so new-fangled and confusing:)
bleep.
out.
Re: [motm] This is an old one...
2001-01-20 by J. Larry Hendry
Didn't  J.W. Barlow (the quiet Stooge) do this before he regained his sanity
and went back to 1/4"?
Larry H
To: <motm@egroups.com>
Sent: Friday, January 19, 2001 4:10 PM
Subject: [motm] This is an old one...
Dave
2001-01-20 by jwbarlow@aol.com
In a message dated 1/19/2001 6:05:31 PM, jlarryh@... writes:
>Larry H
The quiet Stooge???? Damn! I always thought I was the cute Stooge, the smart
Stooge, or at least the funny Stooge!
>----- Original Message -----
>From: Dave Fulton <dfulton@...>
Other than the obvious trigger mod (absolutely necessary for use with the
Serge due to the lack of triggers) for the 800, you'll need to look at
normalized ground connections on some inputs. I know that I was able to
connect a 1M between the input and ground for the switch of the 700 --
otherwise it would hang high regardless of the setting of the voltage knob. I
also ran into problems with the normalized CV inputs on the 410 which need to
see ground to get a good range on the LFO which would go no slower than about
10Hz if left floating -- I chose to leave these floating, and use patch cords
to ground when I used the LFO. There may be a better solution to this, in
fact this was the module that made me decide to change back to the 1/4"
jacks. I don't remember any other problems with the filters though.
I didn't use any adapters to match the size of the bananas to the 1/4"
mounting holes -- I merely lined up the flats on the banana jacks vertically
so they all line up horizontally. I'm sure you can buy a Teflon shoulder
washer from Mouser or any other big place (these types of washers were used
in the older style Serge for mounting the LEDs). I'm sure it would be easy to
determine which size you'd need by the ID and step size OD of the washers and
the OD of the bananas and the ID of the 1/4" mounting holes.
I do sometimes have a problem with bananas (generally) coming loose oc
casionally in the panels (any style panels). This might be reduced with the
use of the shoulder washers.
The only thing I'd be concerned about with such a change is the number of
future modules which may include normalized connections (Paul specifically
mentioned that these would often be part of future design). If your
"customer" intends on buying future MOTM stuff this decision might come back
to haunt him, as it did me.
Good luck!
JB
Re: Stooges
2001-01-20 by Dave Bradley
> > From: <jwbarlow@a...>
> > Stooge, the smart  Stooge, or at least the funny Stooge!
> OK, I'll go smart, and funny (in a warped way), but there is no way
> I am calling you cute (especially since I have seen no photo).
Henceforth:
Barlow will be known as "the guitar stooge".
Hendry will be known as "the torquemeister stooge".
I will be known as "the Gimme an LED stooge".
Moe
Re: [motm] Re: Stooges
2001-01-20 by bigd@buffalo.com
You guys need a stooge IRC channel  : )
> Henceforth:
> Moe
2001-01-20 by Dave Hylander
At 02:09 PM 1/20/01 -0600, you wrote:
>OK, OK., twist the stud out of the back of ONE motm panel and all of the
>sudden I am entered in arm wrestling contests and being called names.
If it makes you feel any better Larry, I did that too....once
-dave-
> From: <jwbarlow@...>
Stooge Larry
Call me stupid (or a stooge), but what is an IRC channel?
Why, I ought to.........
Stooge Larry
