Subject: Re: [newmellotrongroup] Faraday cage
To: "newmellotrongroup@yahoogroups.com" <newmellotrongroup@yahoogroups.com>
Date: Tuesday, August 5, 2014, 12:28 AM
Hope it
helps. Those of us with smartphones
could win big at Scrabble with all the
"authorized" word
re-spellings. Me dum. Me hav no
smurtfone.
-Bruse
On Monday, August 4,
2014 12:17 PM, "'lsf5275@aol.com'
lsf5275@aol.com [newmellotrongroup]"
wrote:
Bruce, my lines come in underground but they
come out of the ground and onto poles outside of the
neighborhood. In my old house I think it might have all been
grounded to the cold water line. Here, our house has a well
the supply comes in in plastic pipe and is pressurized under
the house. As I consider what you have told me I think back
to winter when we has the worst snow/ice storm in decades we
were without power for several days and parts of our area
were out for a week or more. Trees knocked out power lines
and downed poles all over the place and I don't recall
the problems being like that before then... I will call the
power company. Thanks for the tip!
Sent from my Verizon Wireless 4G LTE
DROID
"gino wong wonggster@gmail.com
<newmellotrongroup@yahoogroups.com> wrote:
Don't forget the hat too
Bruce.
On Sun, Aug 3, 2014 at
12:01 PM, Bruce Daily pocotron@yahoo.com
[newmellotrongroup] <newmellotrongroup@yahoogroups.com>
wrote:
Hey Frank and everybody- If
your power source is provided by underground
lines, definitely check your home grounds first. If you
have pole-provided power, have the power company check the
poles for ground line vandalism. Every few poles there is
a ground strap that provides either a neutral system ground,
or earth ground for lightning arrest. Copper
scavengers love to chop as much of the ground straps off of
the poles as they can reach. In the latter case, it is
possible that your home may have a neutral ground that,
because of missing local pole grounds, is miles away. The
long neutral then becomes an antenna. The power company
will gladly fix it.
Personally, I like lotsa
foil on the windows... ;)
-Bruce D.
On Sunday, August 3, 2014 1:01 AM, "lsf5275@aol.com
[newmellotrongroup]" <newmellotrongroup@yahoogroups.com>
wrote:
You suk a proofreding. But you ideas is
good.
In a message dated 8/2/2014 10:41:25 P.M. Eastern
Daylight Time,
writes:
I gey it on everything except my
tron. If you remodel a
room buolding a cage in it is no big deal. iam now
vacating those cage
rooms and have sto start all over again.,
On Sat, Aug 2, 2014 at 6:30 PM, lsf5275@aol.com
wrote:
I live in a
semi-rural area and my home
has five broadcast towers within a half mile or a bit
more. I get radio on
my trons and some of the other older gear. I think the
grounding of my
household is suspect as well.
Frank
In a message dated 8/2/2014 6:20:48 P.M. Eastern
Daylight Time, newmellotrongroup@yahoogroups.com
writes:
I have been buildiong Faraday Cages for
a long time, eve made
some cable tunnels, I am in th shadow of massive
broadcast towers.
I have heard that there are new materials that
survival preppers
use to shield against EMP that is not so
expensive..
I find it interesting that I have had no EMI,
ESDI, or RFI problems
in my Mellotron but my EMS and EML and Buchla and
Serge have all been
either triggered or interfered with in some other
way.
If I can find something better than fine mesh
screening or chivken
rire , I would very very gratteful.
best
gino
Gino Wong
Birgelo BSComm,
BSEE
ReRed
Recording
ReRed
Treehouse Studios at Girard Hall
527 W. Girard
Avenue
Philadelphia, PA
19123
USA
Gino Wong Birgelo
BSComm,
BSEE
ReRed
Recording
ReRed
527 W. Girard
Avenue
Philadelphia, PA
19123
USA
Gino Wong Birgelo
BSComm,
BSEE
ReRed Recording
ReRed Treehouse Studios at Girard
Hall
527 W. Girard
Avenue Philadelphia, PA 19123
USA
#yiv8927948882 #yiv8927948882 --
