HELP on CPU Board Needed...
2006-04-30 by roginator1
HI Group..
Im just in completing third Polysix from 4 non-working P6s...
I have one problem with one CPU Board.....
Hmmmm....
Everything is working ?!? except VCF and adsr section....
I managed to make work program section, arpeggio, Mod section and
VCO....
CPU board is as far as I checked OK  ..cleaned and re-traced ....
added new 7408....also I tried with working CPU board from other
Polysix and then P6 work.....
anybody had this problem?????
any cure...I cant find wich part on CPU Board is not working
VCF controls acts strange
HELP
Damir
Re: [PolySix] HELP on CPU Board Needed...
2006-05-01 by akira honda
check de pcb traces comming for that section... maybe one of those it's broken, specially if the battery was leacked chekc the switches .. there are many things that could cause that problem.  .. check the schematic to find out the traces. I had a similar problem..
  good luck,
roginator1 <roginator1@yahoo.com> wrote:
  HI Group..
Hmmmm....
VCO....
HELP
Damir
PolySix "Digiest" Page: http://www.acc.umu.se/~amber/Poly6
  SPONSORED LINKS
        Electronic instrument   Synthesizer music   Electronic music     Music sampler   Electronic musical instrument
  YAHOO! GROUPS LINKS
    Visit your group "PolySix" on the web.
 PolySix-unsubscribe@yahoogroups.com
How low will we go? Check out Yahoo! Messenger’s low  PC-to-Phone call rates.
Re: HELP on CPU Board Needed...
2006-05-06 by darke_one666
you made need to set up the D/A and offset as this interprets the
position of all the pots.
--- In PolySix@yahoogroups.com, "roginator1" <roginator1@...> wrote:
> HI Group..
> Hmmmm....
> VCO....
> HELP
> Damir
