polysix altzheimers
polysix altzheimers
2007-05-15 by spistrich
I just did a battery transplant on a polysix i just got that had a
leaky battery... not too bad, but there were a few (4-5) blackened
traces around IC31, but they all tested as conductive, so I left them
alone.So upon reassembly the LEDs for bank A and #1 stay on all the
time. the other LEDs all go on/off as you push their buttons, but A and
1 stay lit. And  new writing doesnt seem to enter the memory (no
recall). Would those 4-5 traces around IC31 be the problem?  Could IC31
itself be bad? what does it do? Is IC31 the "memory chip"? The rest of
the board seems fine. Any ideas?
Re: polysix altzheimers
2007-05-15 by gmanca101
Based on Old Crow's stuff, ic 31 isn't a memory chip, it's a gate
that's used sometimes for controlling leds and in this case it does.
So that's your LED problem most likely.
Just from experience with corrosion; it can travel in ways that you
wouldn't think are possible. It can travel through wire harnesses and
cause traces on other sides of boards to errode.
I'd just double check with Old Crow's schematics based on what you
have issues with.
Re: [PolySix] polysix altzheimers
2007-05-15 by Chromatest J. Pantsmaker
black traces are bad.  They will continue to corrode and spread
cancer.  You should clean it all away.
> PolySix "Digiest" Page: http://www.acc.umu.se/~amber/Poly6
.sig
-Chromatest J. Pantsmaker
http://www.chromatest.net
