Anyone know how it really works?
2008-08-29 by Andrew Jury
Hi!
I have just released with my MG (LFO) seems to be running very slowly
with the frequency knob at 10. Before I dip in with my soldering iron
does anyone know how the MG oscillator works? I have studied the
schematic and there is nothing in the design which looks remotely like
one! I believe the MG should run at 50Hz flat out. My 'scope says just
over 3Hz when I measure at the VCA MOD test point. There is an RC
network connected to the gate of Q1 on the KLM-367 which possibly
triggers a voltage at the drain over a time period. The RC nework
values (R27, C19) 10K, 0.33uF equate to a frequency of just over 48Hz,
which looks promising. Can anyone shed any light on how this bit of the
P6 works?
(A)
Re: [PolySix] Anyone know how it really works?
2008-08-29 by Johannes Hausensteiner
The oscillator design is of the multivibrator type. The not so common
thing is that it is voltage controlled.
The control voltage is buffered by IC13. it is converted to current
by R16, R69, TH1 combination (temperature compensated by use of TH1).
This current is mirrored by dual-transistor (for good match) Q3. The
mirrored current is fed into control input of transconductance amplifier
1/2 of IC21. Download the data sheet of this IC to find out how it
works. LM13700, NE5517, CA3080 are similar devices. It is an amplifier
with voltage input (high impedance) and current output (high impedance),
hence the name transconductance (current divided by voltage is called
conductance, the reciproke of resistance). So you input a voltage and
get a current on the output. That is the reason why timing capacitor
C19 does not have any resistor associated with. The transconductance
(= similar to gain of opamps) is controlled by the current which is
drawn out of the control pin (pin16).
One half of IC16 is the other vital part of the multivibrator circuit,
it acts as the schmitt trigger (positive feedback).
How does it work?
Lets assume any voltage level on IC16/pin6 after power on. It will be
more or less than the voltage on IC16/pin5. Depending whether it is
more or less the output of IC16 will be positive or negative saturated,
which is about +Vcc -1.5V or -Vcc +1.5V (+/-13.5V). This voltage is
divided by resistor divider R53 - R52 and fed into the transconductance
amp. Depending on the control current the output of IC21 delivers a
proportional current. This current charges the timing capacitor C19
developing a linear ramp voltage. The high impedance voltage is buffered
by JFET Q1 and fed back to IC16 input. When it reaches the same level
as voltage on IC16/pin5 the output switches to other saturation level
and C19 is being discharged until IC16/pin6 trips pin5 and the output
reverses polarity again (multivibrator principle). Since the output
current of IC21 is controlled by the control current, which in turn is
determined by the "MP SPEED" control voltage, the oscillation frequency
is controlled (larger current charges/discharges the timing capacitor
faster). Is it clear?
What can go wrong? - Anything 8-/.
I assume you did the adjustment procedure for MG speed (VR5). The
service manual says, "If these values (50Hz) cannot be obtained after
replacing IC LM13600, adjust R78 and R52 respectively."
First check the control voltage (IC13/pin7). It should reach -5 .. +5V.
Next check the output swing of IC16 (pin7) it should be at least +/-13V.
Next compare voltages before and after the buffer Q1; should be (nearly)
equal.
More measurements are not so easy because it is all current driven; you
cannot simply measure voltages. Best thing to try is replacing components
(C19, IC21, Q3, maybe TH1). If you dont find a dual transistor you can
use two discretes of the same type (would be good of the same lot).
Good luck!
Johannes
Andrew Jury wrote:
> Hi!
> P6 works?
> Thanks,
> (A)
Re: Anyone know how it really works?
Johannes,
This is an extremely comprehensive answer. Many thanks for taking the
time to explain. Let me read carefully, disgest and perform some more
tests on the LFO. I'll let you know what I find!
Best wishes,
Andy
--- In PolySix@yahoogroups.com, Johannes Hausensteiner <johau@...>
common
TH1).
amplifier
amplifier
impedance),
called
and
circuit,
> How does it work?
be
saturated,
transconductance
buffered
level
level
output
is
frequency
capacitor
after
+5V.
13V.
(nearly)
> equal.
you
components
can
> Good luck!
> Johannes
> Andrew Jury wrote:
> > Hi!
slowly
iron
like
just
48Hz,
of the
> > P6 works?
> > Thanks,
> > (A)
2008-08-31 by Andrew Jury
Johannes,
After a major fault finding session I would like to report back the
following:
The first thing I did was be rather lazy and swap the transconductanc
op-amp IC21 to see if it made any difference; no! I then checked the
FET Q1 s-g, g-d and g-d. Similarly I checked the matched pair of bi-
polars at Q3 c-b, b-e and c-e. No problems. I then very carefully
checked all the resistors in circuit, including VR5, which all
checked OK. I tested C19 which 0.339uF. Not bad for an electrolytic
which is over 25 years old! The MG was still ocillating flat out at
3.4hz even with VR5 at it uppermost setting. I then checked the dc
voltage present at pin 7 of IC13. Changing the MG frequency control
from 0 (+ 4.98V) to 10 (-0.17v). But wait? Can this be right? I
checked pin 12 of IC19 which is the mux output X3; same voltage
reading. Working back to IC2 on the KLM-370 board I checked the mux
input X2 at pin 15. The voltage swings accurately around the
frequency pot wiper from +5 to -5v. However, taking a reading at the
muxed data output on pin 3 of IC2 the voltage will only swing as
mentioned before from +4.98 to -0.17v. Now forgive me if I am wrong
but I understood the HA14051 worked like this. You appliy a voltage
to one of the 8 mux inputs marked X0-7. The voltage change is
detected and a bitmap is set on data address lines A, B and C
according to which pin was strobed. At the other end this bitmap is
decoded the data read on the receiving mux and the appropriate signal
(in this case a voltage) will appear at the correct pin as determind
by the bitmap. The fact that the voltage doesn't swing correctly
between the two poles of the pot would suggest a fault with the
transmitting HA14051? Am I right in assuming this? If the address
lines were cut/missing then some of the muxed output would be never
selected and hence always at 0 volts. This might also account for the
other problem in that the ADS bit of the EG works (sort of!) but the
release pot does nothing! (Again the voltage swings about the same as
the MG frequency control)
Your expert opinion on this matter is greatly anticipated!
Best regards,
Andy
common
TH1).
amplifier
amplifier
impedance),
called
and
circuit,
> How does it work?
be
saturated,
transconductance
buffered
level
level
output
is
frequency
capacitor
after
+5V.
13V.
(nearly)
> equal.
you
components
can
> Good luck!
> Johannes
> Andrew Jury wrote:
> > Hi!
slowly
iron
like
just
48Hz,
of the
> > P6 works?
> > Thanks,
> > (A)
2008-09-01 by synx508
That's how it works, but before you go suspecting the mux, are you sure you're getting
the full range of digital data on A, B and C at both ends?  The at both ends bit being really
important, on one of my KLM-367s I had the right signals present right up to within 1mm
of the connector, at which point one of my mux selection signals became something
entirely different thanks to the wonderful way the nicad redesigned the board.
Sorry about the over-zealous quote snipping, btw.
phil
2008-09-01 by radek_tymecki
Remember that MG is connected with frequency knob. If it runs low on
max setting then first try to look at dead lfo capacitors
Re: [PolySix] Re: Anyone know how it really works?
2008-09-01 by Johannes Hausensteiner
Andrew,
Yes, the voltage must swing between -5V and +5V. It is not so easy
to tell whether it happens on the input side (KLM-369/370) or the
output side (KLM-367). Do the following:
* connect CH2 of your scope to testpoint "TP4 CLOCK" on KLM-367.
   It is right beneath the 8048 CPU, IC22. Set the trigger to CH2
   and adjust the trigger level to see a narrow pulse every 20msec.
* connect CH1 of scope to test point "TP2", which is right beneath
   the "RESET ADJ" poti, VR1.
* select MANUAL on the Polysix front panel and turn all knobs
   fully left. The scope reading should be mainly -5V. There may be
   some garbage at the end of the cycle.
* now turn each knob fully up and down again. You should see a
   small "bar" going from -5V to +5V. Depending on the knob the
   position within the cycle is different. The order is according
   to the outputs of 4051 multiplexers IC18, IC19.
   What you see is the analog CV /output/
* Move the CH1 probe to CN11/pin2, labeled "DATA". Here you will
   see a similar thing; the bars will be different in length, but
   the principle is the same. Again turn each knob up and down.
   Observe that each knob reaches the full span of -5 .. +5V.
   This is the /input/ side.
Now you can judge if the fault is a 4051 on KLM-369/370 or KLM-367.
If you have problems to interpret the scope screen take pictures and
email them. I will try to figure out what's wrong.
Note: I had it once or twice that the leaked acid from the NiCd
battery crawled via the GND connection (thick black wire) from
KLM-367 to KLM-370 and did damage there. Check for this!
Good luck !
Johannes
Andrew Jury wrote:
> Johannes,
> following:
> Best regards,
> Andy
> common
> TH1).
> amplifier
> amplifier
> impedance),
> called
> and
> circuit,
>> How does it work?
> be
> saturated,
> transconductance
> buffered
> level
> level
> output
> is
> frequency
> capacitor
> after
> +5V.
> 13V.
> (nearly)
>> equal.
> you
> components
> can
>> Good luck!
>> Johannes
>> Andrew Jury wrote:
>>> Hi!
> slowly
> iron
> like
> just
> 48Hz,
> of the
>>> P6 works?
>>> Thanks,
>>> (A)
> PolySix "Digiest" Page: http://www.acc.umu.se/~amber/Poly6Yahoo! Groups Links
2008-09-01 by Andrew Jury
Phil,
No, please do quote away! This is interesting because the KLM-367
board on this P6 was pretty badly burnt with blue nickel cadmium
pixie dust. It would make sense it suspect further broken tracks
which I might of missed. I will check the data line and the inhibit
continuity for the whole circuit and see if there are any breaks. Can
you just confirm that the receiving mux's output should swing between
+5 and -5 and not +5 and -0.17v! I guess I know what you are going
say...
In my case I am assuming this is why I can't get the MG to oscillate
above 3.4Mhz. If the swing reached -5v then I might get the full 50hz.
Thanks and I will let you know what gives...
Andy
voltage
is
signal
determind
sure you're getting
became something
the board.
> phil
2008-09-04 by Andrew Jury
Seem to be getting nowhere fast with this one. I made the
observations with the oscilloscope you mentioned and seemed to be
able to reproduce the waveforms you described, if a little on the low
voltage side.
However, careful study of the schematic reveals that the tansmitting
and receiving mux are not directly connected. Which adds to the
confusion! The data from the pin 3 of the 14051 on the control panel
terminates on the non-inverting input of comparator IC6. The voltage
being compared is that fed back from from the output of the D/A
converter IC33. My guess is that when you turn one of the pots on the
multiplexed bus the actually control is provided by the logic of the
CPU programmed via pin T0. This would mean that the actually
multiplexed voltages are actually controlled by the D/A converter
rather than receiving the raw voltages directly from the transmit end
(if that makes sense). Now here is the bombshell... The DC voltage at
pin 4 of the D/A converter is always 0v (strictly 0.00v, like it is
grounded, which it isn't!) The output of op-amp IC27 varies only a
matter of millivolts when the controls are turned, which would
explain the weird MG control and lack of release on the VCA. So I am
guessing that the data bus d0-d7 is low/missing? I noticed on this
board the 1408 has been replaced in the past with a DAC08. Looks pin
compatible, but maybe not.
Oh, and you'll like this! I managed to purloin a working KLM-367 from
a friend and transplanted it into my P6. It works fine showing all
the peripheral circuitry is working ok. Back to the continuity
testing...
Andy
2008-09-05 by Johannes Hausensteiner
Of course, this is the reason fo rall that multiplex stuff. The
analog controlo voltages are digitised (via the D/A converter)
under software control and saved in the battery backed memory.
Otherwise the patches could not be saved and recalled. And yes,
(of course) this is all under software control by the 8048 CPU.
The 1408 DAC chip (it IS compatible with the DAC08) has, like
many DACs of this design a current output. You will notice that
there is no resistor in series to the inverting input of the
following opamp as it is normally the case for an inverting
amplifier. IC27/pin2 (which is the same point as DAC/pin4) is
the /virtual ground/ of the opamp; this means the opamp does all
it can (like all opamps with negative feedback) to make the
voltage difference between its two inputs zero. So we know from
your measurement 0V (few mV) at DAC/pin4 that opamp IC27 is
working.
Comparator IC6 works in conjunction with the software and the DAC
similar like a neg. feedbacked opamp: the voltage between its two
inputs is minimised. It is not perfect (by design) because it is
a digital feedback loop, which means it has discrete steps of
+5-(-5)V / 256 steps, which happens to be ca. 39mV.
So the reason of your problem may lie in IC6, the DAC, or associated
components or the software. Since we know that the software works
(what a rare case!) it only can be that the data bus is corrupted,
which is the most likely reason in the case of a battery leaked
Polysix.
Do you get the full span (-5 .. +5V) for other control voltages?
What is the voltage difference between pin2 and pin3 of IC6?
Are there good logic levels on CPU/pin1 and on all of the 8 data
lines of the DAC?
Is the reference voltage of the DAC (pin14; generated by 2nd half
of IC27) OK?
In any case, if there is a problem with the DAC or comparator or
data lines /all/ CVs are affected. If it is only certain CVs then
the problem lies in the multiplexer and demultiplexer circuits
(4051 chips on KLM369/370 and KLM367).
Johannes
Andrew Jury wrote:
> Hi,
> voltage side.
> testing...
> Cheers,
> Andy
2008-09-18 by Andrew Jury
This one is really turning into a pig!
Here's what I have done and still I have a sweep voltage on each
demux output from -4.58 to 0.16v. Just imagine what this P6 sounds
like with only partial control over it's functions!
1. An agressive continuity check on data bus lines DO0-7. All OK
2. The following ICs replaced IC6, IC33, IC27, IC18, IC19
3. The P6 works fine when a replacement KLM-367 is fitted from a
working unit.
I must admit it sounds like one of the positive supply rails is
missing. However, all the silicon seems to be supplied with the right
voltages. All I can assume is that the inbound muxed voltage lines at
X (pin 3) are wrong and this implies that the d/a converter is not
playing back the correct voltage steps when the various different
bitmaps are applied to the data bus.
Why this one sided representation of the input voltage? Bah! Will my
hair ever grow back!?
Andy
> working.
> Polysix.
> lines of the DAC?
> of IC27) OK?
> Johannes
> Andrew Jury wrote:
> > Hi,
low
> > voltage side.
tansmitting
panel
voltage
end
voltage at
is
a
am
this
pin
from
all
> > testing...
> > Cheers,
> > Andy
Groups Links
2008-09-19 by Andrew Jury
If you have been following the sorry tale of my P6 repairs then a
small word of warning for you. If you ever need to change the d/a
converter (IC33) or come across a non-working one where it has been
changed beware! My KLM-367 had a DAC08 fitted. This is supposed to be
pin compatible with the HA17408P which it replaces. IT ISN'T!
Pin 1 on the original chip is not connected, however, on the
replacement it needs to be grounded! A small blob of solder
connecting pins 1 and 2 and the KLM-367 is now back in full working
order.
One for the field notebook I fear...
Andy
P.S. The 'Alldatasheet.com' website is a lifesaver!
> Hi,
> working unit.
right
at
my
> Cheers,
> Andy
> --- In PolySix@yahoogroups.com, Johannes Hausensteiner <johau@>
> > working.
associated
> > Polysix.
> > lines of the DAC?
> > of IC27) OK?
> > Johannes
> > Andrew Jury wrote:
> > > Hi,
be
> low
> > > voltage side.
> tansmitting
> panel
> voltage
on
> the
of
> the
converter
transmit
> end
> voltage at
it
> is
only
> a
I
> am
> this
Looks
> pin
367
> from
> all
> > > testing...
> > > Cheers,
> > > Andy
> Groups Links
