Hi Ian,
It most certainly is and this is something I have had to do on a few
occasions. The series feed resistor also needs changing depending on the
spec of the LED. Use ohms law to figure that one out! I¹ll write you you
shortly ;-)
Andy
On 08/10/2010 16:46, "silvercreekvalley" <silvercreekvalley@yahoo.com>
wrote:
> As part of my polysix 'refit' I'd like to replace
> the red led's with blue ones. Is this likely to be
> a problem - I'm assuming the red leds are fairly
> standard size and voltage?
> The switches seem to have a built in led, and I wonder
> if its possible to replace those at all?
> Anybody given this a try?
> Ian
