P6 power transistor
P6 power transistor
2011-04-07 by klosmon
I'm trying to locate a replacement for the 2sb744 power transistor on
the P6 power supply board --
I know this component is faulty (successfully swapped in a working
transistor from another unit).
This particular number seems to be obsolete, and I haven't had luck
finding an equivalent.
Can anyone point me in the right direction?
Thanks.
~GMM
Re: [PolySix] P6 power transistor
2011-04-07 by Jed Jorgensen
Would an MJE172 work?
> Thanks.
> ~GMM
2011-04-07 by Andrew Jury
You could try an Motorola MJE253, but check the pin out (should go e-c-b).
This is a nice replacement for linear PSU circuits as it has a matched pair
MJE243 (NPN)  and both are in a TO-126 package.
Andy
> Thanks.
> ~GMM
Tried that, thanks.  Works with no load, but doesn't work when the
modules are connected.
~G
>     Thanks.
>     ~GMM
Re: P6 power transistor
2011-04-08 by Scott
> Thanks.
> ~GMM
Best place for vintage transistors and subs:
http://www.ceitron.com/semi/semi.phtml?part=2sb744
Almost always in stock 98% of the time
2011-04-08 by Johannes Hausensteiner
The data sheet of the 2SB744 tells the important values:
PNP, TO-126 E-C-B, Ic=3A, Uce=45V (60V for 2SB744A), Ptot=10W (with heat
sink)
Lets see what we can find:
BD180:
PNP, TO-225 E-C-B, Ic=3A, Uce=80V, Ptot=30W (with heat sink)
TO-225 looks from the drawings the same as TO-126.
BD438:
PNP, TO-126 E-C-B, Ic=4A, Uce=45V, Ptot=36W (with heat sink)
2N5195:
PNP, SOT-32 E-C-B, Ic=4A, Uce=80V, Ptot=40W (heat sink)
SOT-32 is the same as TO-126
all available at Farnell
> Thanks.
> ~GMM
> PolySix "Digiest" Page: http://www.acc.umu.se/~amber/Poly6Yahoo! Groups Links
