Cross for a 2SC2765?
2011-07-18 by Mike
2011-07-18 by Mike
Has anybody crossed a 2SC2765 PolySix PSU transistor with a generic 2N* American Version? I'm low on fuses and don't want to make a mistake or give this PSU more time than it deserves.
2011-07-18 by Mike
It might be 2SC2785... --- In PolySix@yahoogroups.com, "Mike" <mborish_2000@...> wrote:
> > Has anybody crossed a 2SC2765 PolySix PSU transistor with a generic 2N* American Version? > > I'm low on fuses and don't want to make a mistake or give this PSU more time than it deserves. >
2011-07-19 by Andrew Jury
Hi Mike, Which position in the PSU have you retrieved this transistor from? Cheers, Andy On 18/07/2011 22:45, "Mike" <mborish_2000@yahoo.com> wrote: > > > > > > It might be 2SC2785... > > --- In PolySix@yahoogroups.com <mailto:PolySix%40yahoogroups.com> , "Mike" > <mborish_2000@...> wrote: >> > >> > Has anybody crossed a 2SC2765 PolySix PSU transistor with a generic 2N* >> American Version? >> > >> > I'm low on fuses and don't want to make a mistake or give this PSU more >> time than it deserves. >> > > > > > > [Non-text portions of this message have been removed]
2011-07-19 by Mike
Q5 is where I got the transistor from. I'm pretty sure that it's a 2sc2785. If I remember correctly from studying power supplies, it is a current overload protection transistor; when the current on R2 gets high enough to create a 0.7 v drop across the BE junction of Q5, Q5 turns on and shuts down Q2. I'm going to give Q2 the good old diode test now that I think about it because it might also be faulty. Its been about six or seven months since I've been in this synth and I don't remember exactly what I did to it. On another note, I've also got a KLM-367 clone that I never got working. Obviously, I've got to get the 5 volt rail up first before I can find the problem in the KLM-367. Thanks, Mike --- In PolySix@yahoogroups.com, Andrew Jury <andy@...> wrote:
> > Hi Mike, > > Which position in the PSU have you retrieved this transistor from? > > Cheers, > Andy > > > On 18/07/2011 22:45, "Mike" <mborish_2000@...> wrote: > > > > > > > > > > > > > It might be 2SC2785... > > > > --- In PolySix@yahoogroups.com <mailto:PolySix%40yahoogroups.com> , "Mike" > > <mborish_2000@> wrote: > >> > > >> > Has anybody crossed a 2SC2765 PolySix PSU transistor with a generic 2N* > >> American Version? > >> > > >> > I'm low on fuses and don't want to make a mistake or give this PSU more > >> time than it deserves. > >> > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] >
2011-07-19 by Scott
--- In PolySix@yahoogroups.com, "Mike" <mborish_2000@...> wrote: > > Q5 is where I got the transistor from. I'm pretty sure that it's a 2sc2785. If I remember correctly from studying power supplies, it is a current overload protection transistor; when the current on R2 gets high enough to create a 0.7 v drop across the BE junction of Q5, Q5 turns on and shuts down Q2. > > I'm going to give Q2 the good old diode test now that I think about it because it might also be faulty. Its been about six or seven months since I've been in this synth and I don't remember exactly what I did to it. > > On another note, I've also got a KLM-367 clone that I never got working. Obviously, I've got to get the 5 volt rail up first before I can find the problem in the KLM-367. > > Thanks, > Mike > http://www.bdent.com/SearchResults.asp?Search=+2sc2785&Search.x=0&Search.y=0 ( for a 2sc2785)
Hi Mike, Q5 should be a 2SC945 so you could try our old friend the 2N2222! Cheers, Andy On 19/07/2011 10:51, "Mike" <mborish_2000@yahoo.com> wrote: > > > > > > Q5 is where I got the transistor from. I'm pretty sure that it's a 2sc2785. > If I remember correctly from studying power supplies, it is a current overload > protection transistor; when the current on R2 gets high enough to create a > 0.7 v drop across the BE junction of Q5, Q5 turns on and shuts down Q2. > > I'm going to give Q2 the good old diode test now that I think about it because > it might also be faulty. Its been about six or seven months since I've been > in this synth and I don't remember exactly what I did to it. > > On another note, I've also got a KLM-367 clone that I never got working. > Obviously, I've got to get the 5 volt rail up first before I can find the > problem in the KLM-367. > > Thanks, > Mike > > --- In PolySix@yahoogroups.com <mailto:PolySix%40yahoogroups.com> , Andrew > Jury <andy@...> wrote: >> > >> > Hi Mike, >> > >> > Which position in the PSU have you retrieved this transistor from? >> > >> > Cheers, >> > Andy >> > >> > >> > On 18/07/2011 22:45, "Mike" <mborish_2000@...> wrote: >> > >>> > > >>> > > >>> > > >>> > > >>> > > >>> > > It might be 2SC2785... >>> > > >>> > > --- In PolySix@yahoogroups.com <mailto:PolySix%40yahoogroups.com> >>> <mailto:PolySix%40yahoogroups.com> , "Mike" >>> > > <mborish_2000@> wrote: >>>>> > >> > >>>>> > >> > Has anybody crossed a 2SC2765 PolySix PSU transistor with a generic 2N* >>>> > >> American Version? >>>>> > >> > >>>>> > >> > I'm low on fuses and don't want to make a mistake or give this PSU more >>>> > >> time than it deserves. >>>>> > >> > >>> > > >>> > > >>> > > >>> > > >>> > > >> > >> > >> > >> > [Non-text portions of this message have been removed] >> > > > > > > [Non-text portions of this message have been removed]
