Tuning problem
Tuning problem
2012-04-30 by klosmon
Hello-
I'm working on an older version voice board (with the 396 add-on board)
that won't tune.
The six oscillators can be tuned to match at the low points & high
points, but there's no way to tune them to play anything like a
half-tone scale.
I've tried the usual (replace the optoisolator, replace the 4051,
replace the dual transistor, replace the TL071 opamp), but nothing helps.
Any ideas where else I should be looking?
Thanks.
~G
Re: [PolySix] Tuning problem
2012-04-30 by Andrew Jury
Probably some issues in the anti-log circuit. To verify note the voltages at
IC31 pin 3. Try a C in each octave. This voltage should ramp up in a linear
fashion as the frequency increases. If not try replacing IC30 (you have
replaced IC31 already, right?). Also take a look at IC19. The A side of it
is a precise voltage reference (output should be 9V). If this is wrong you
might be in trouble. Also make sure that if you replaced Q12 that the new
device is a matched pair and thermally bonded. Two BC549s glued together
just won¹t cut it, but you probably know that!
Andy
On 30/04/2012 18:36, "klosmon" <klosmon@sbcglobal.net> wrote:
> Hello-
> that won't tune.
> half-tone scale.
> Thanks.
> ~G
2012-05-03 by klosmon
Hola-
Replaced some CMOS with no result, finally had success with a new 4558
at IC19.
Thanks for the help -- this didn't used to be so difficult, but with 4
to 6 repairs going at once (and more on the way), it's difficult to
focus like I'm supposed to.
Looking forward to a break soon....
Thanks again.
~G
Andrew Jury wrote:
> Hi,
> voltages at
> linear
> Cheers,
> Andy
> <mailto:klosmon%40sbcglobal.net>> wrote:
> > Hello-
> > that won't tune.
> > half-tone scale.
> helps.
> > Thanks.
> > ~G
Polysix tact switch.
2012-08-09 by Mike
> Hey all.
Does anyone know the model of tact switch used in the polysix and poly 61?
I'm guessing a C&K switch, but a mouser part number would be great.
(I'm referring to the tact switch under the special switch cap)
Kind regards
Mike
Re: Polysix tact switch.
2012-08-09 by tonezone020
Hi Mike,
I believe the OMRON  B3F 4000 are perfect for the job...
Mouser 653-B3F-4000
Best wishes,
Tony
--- In PolySix@yahoogroups.com, Mike <mrjdevries@...> wrote:
> > Hey all.
> Kind regards
> Mike
Re: [PolySix] Re: Polysix tact switch.
2012-08-09 by Mike
Legend!
Thanks!
Sent from my Apple ][e
On 10/08/2012, at 1:27 AM, "tonezone020" <swamp.gigs@googlemail.com> wrote:
> Hi Mike,
> Mouser 653-B3F-4000
> Best wishes,
> Tony
> > > Hey all.
> > Kind regards
> > Mike
2012-08-09 by syntegrator
Tony,
Thanks very much from me too for this information - I've been looking for a Mouser/Digikey/Farnell part number for these switches for a while now.
I'll be sure to post this information as a video in my YouTube channel Polysix rebuilding playlist once the parts arrive and I can compare them with the originals.
Syntegrator
--- In PolySix@yahoogroups.com, "tonezone020" <swamp.gigs@...> wrote:
> Hi Mike,
> Mouser 653-B3F-4000
> Best wishes,
> Tony
> --- In PolySix@yahoogroups.com, Mike <mrjdevries@> wrote:
> > > Hey all.
> > Kind regards
> > Mike
Cool Syntegrator,
I found your series on the Juno really helpful.
Tony
--- In PolySix@yahoogroups.com, "syntegrator" <me@...> wrote:
> Tony,
> Cheers,
> Syntegrator
> --- In PolySix@yahoogroups.com, "tonezone020" <swamp.gigs@> wrote:
> > Hi Mike,
> > Mouser 653-B3F-4000
> > Best wishes,
> > Tony
> > > > Hey all.
> > > Kind regards
> > > Mike
RE: [PolySix] Re: Polysix tact switch.
2012-08-09 by philippe.69
Hello  the switch on sale here
http://cgi.ebay.fr/ws/eBayISAPI.dll?ViewItem&item=320957868876&ssPageName=ST
RK:MESELX:IT&_trksid=p3984.m1586.l2649
De : PolySix@yahoogroups.com [mailto:PolySix@yahoogroups.com] De la part de
syntegrator
Envoyé : jeudi 9 août 2012 21:27
À : PolySix@yahoogroups.com
Objet : [PolySix] Re: Polysix tact switch.
Tony,
with the originals.
Syntegrator
--- In  <mailto:PolySix%40yahoogroups.com> PolySix@yahoogroups.com,
"tonezone020" < <mailto:swamp.gigs@...> swamp.gigs@...> wrote:
> Hi Mike,
> Mouser 653-B3F-4000
> Best wishes,
> Tony
> --- In PolySix@yahoogroups.com <mailto:PolySix%40yahoogroups.com> , Mike
> > > Hey all.
61?
> > Kind regards
> > Mike
2012-08-09 by Mike
That's only about 20x as expensive as mouser!
> syntegrator
> Tony,
> with the originals.
> Cheers,
> Syntegrator
> > Hi Mike,
> > Mouser 653-B3F-4000
> > Best wishes,
> > Tony
> > > > Hey all.
> 61?
> > > Kind regards
> > > Mike
An update here for everyone...
I did some correlating with the infamous Murray over at kiwitechnics.com (the company that is currently working on the Kiwisix upgrade for Korg Polysix) - He agrees this part number will work, BUT he recommends the 'Long Service Life' version instead of the standard one.
Part number is nearly identical: It's a 5000 instead of a 4000:
Mouser 653-B3F-5000
In terms of cost the long service life version is 55 cents each (when ordering 25) instead of 45 cents. I can spare $2.50 for the extra peace of mind that 10 years along it won't need replacing... ;-)
Cheers!
Syntegrator
> > syntegrator
> > Tony,
> > with the originals.
> > Cheers,
> > Syntegrator
> > "tonezone020" < <mailto:swamp.gigs@> swamp.gigs@> wrote:
> > > Hi Mike,
> > > Mouser 653-B3F-4000
> > > Best wishes,
> > > Tony
> > > > > Hey all.
> > 61?
> > > > Kind regards
> > > > Mike
Ahh ... even better !
Cheers.
T
> Mouser 653-B3F-5000
> Cheers!
> Syntegrator
> > > syntegrator
> > > Tony,
> > > with the originals.
> > > Cheers,
> > > Syntegrator
> > > > Hi Mike,
> > > > Mouser 653-B3F-4000
> > > > Best wishes,
> > > > Tony
> > > > > > Hey all.
> > > 61?
> > > > > Kind regards
> > > > > Mike
2012-08-14 by Roman Sowa
Poly 61 uses different switches, with square thingies peeking out, and
the plastic Korg key is pushed on it. The part name is Omron B3F-5050,
but the square is tiny bit too wide for the cap so it needs to be filed.
Poly 6 uses flat switches, so B3F-5000.
Roman
W dniu 2012-08-10 00:14, Mike pisze:
>> syntegrator
>> Envoy� : jeudi 9 ao�t 2012 21:27
>> � : PolySix@yahoogroups.com
>> Tony,
>> with the originals.
>> Cheers,
>> Syntegrator
>> --- In<mailto:PolySix%40yahoogroups.com>  PolySix@yahoogroups.com,
>> "tonezone020"<  <mailto:swamp.gigs@...>  swamp.gigs@...>  wrote:
>>> Hi Mike,
>>> Mouser 653-B3F-4000
>>> Best wishes,
>>> Tony
>>> --- In PolySix@yahoogroups.com<mailto:PolySix%40yahoogroups.com>  , Mike
>>>>> Hey all.
>> 61?
>>>> Kind regards
>>>> Mike
2012-08-17 by syntegrator
Hey everyone,.
I've made and posted a few videos to the Syntegrator channel on this topic now that the parts arrived:
http://www.youtube.com/watch?v=O98fX99onfY&list=PL3B188553B60870EE&index=39&feature=plpp_video
Enjoy,
Syntegrator
> Roman
> >> syntegrator
> >> Tony,
> >> with the originals.
> >> Cheers,
> >> Syntegrator
> >> "tonezone020"<  <mailto:swamp.gigs@>  swamp.gigs@>  wrote:
> >>> Hi Mike,
> >>> Mouser 653-B3F-4000
> >>> Best wishes,
> >>> Tony
> >>>>> Hey all.
> >> 61?
> >>>> Kind regards
> >>>> Mike
> > Yahoo! Groups Links
2012-08-19 by philippe.69
original for sale here
http://cgi.ebay.fr/ws/eBayISAPI.dll?ViewItem&item=320966335753
De : PolySix@yahoogroups.com [mailto:PolySix@yahoogroups.com] De la part de syntegrator
Envoyé : samedi 18 août 2012 01:16
Hey everyone,.
 <http://www.youtube.com/watch?v=O98fX99onfY&list=PL3B188553B60870EE&index=39&feature=plpp_video> http://www.youtube.com/watch?v=O98fX99onfY&list=PL3B188553B60870EE&index=39&feature=plpp_video
Enjoy,
Syntegrator
--- In  <mailto:PolySix%40yahoogroups.com> PolySix@yahoogroups.com, Roman Sowa < <mailto:modular@...> modular@...> wrote:
> Roman
> > On 10/08/2012, at 4:07 AM, "philippe.69"< <mailto:philippe.69@...> philippe.69@...> wrote:
> >> http://cgi.ebay.fr/ws/eBayISAPI.dll?ViewItem <http://cgi.ebay.fr/ws/eBayISAPI.dll?ViewItem&item=320957868876&ssPageName=ST> &item=320957868876&ssPageName=ST
> >> De : PolySix@yahoogroups.com <mailto:PolySix%40yahoogroups.com>  [mailto:PolySix@yahoogroups.com <mailto:PolySix%40yahoogroups.com> ] De la part de
> >> syntegrator
> >> À : PolySix@yahoogroups.com <mailto:PolySix%40yahoogroups.com>
> >> Tony,
> >> with the originals.
> >> Cheers,
> >> Syntegrator
> >> --- In< <mailto:PolySix%40yahoogroups.com> mailto:PolySix%40yahoogroups.com>  <mailto:PolySix%40yahoogroups.com> PolySix@yahoogroups.com,
> >> "tonezone020"< < <mailto:swamp.gigs@> mailto:swamp.gigs@>  <mailto:swamp.gigs@> swamp.gigs@> wrote:
> >>> Hi Mike,
> >>> Mouser 653-B3F-4000
> >>> Best wishes,
> >>> Tony
> >>> --- In PolySix@yahoogroups.com <mailto:PolySix%40yahoogroups.com> <mailto:PolySix%40yahoogroups.com> , Mike
> >>>>> Hey all.
> >> 61?
> >>>> Kind regards
> >>>> Mike
> > Yahoo! Groups Links
2018-05-08 by Malte Rogacki
Just to make sure before thinking further:
You're holding a note and then turn off the Chorus: The pitch of the held
note changes.
You're holding a note and changing the modulation level: The pitch of the
held note changes.
Is that correct?
2018-05-16 by Peter Foley
I think that some tuning weirdness can happen if the optocoupler is bad - I would check that. The KiwiSix manual describes how a bad optocoupler would behave.
- Peter
On Tue, May 8, 2018 at 5:41 PM, Malte Rogacki gacki@gacki.sax.de [PolySix] <PolySix@yahoogroups.com> wrote:
note changes.
held note changes.
Is that correct?
2018-05-16 by moogchild synthdrome
I have for sale direct replacements for the Polysix optocoupler, price is 36€ worldwide shipping included buying it directly outside ebay. You can contact me at info@moogchild-synthdrome.com.
Korg Polysix direct replacement for OPTOCOUPLER HTV P-1501 PHOTOCOUPLER PC-1 | eBay
| $39.99 |  |
Korg Polysix direct replacement for OPTOCOUPLER HTV P-1501 PHOTOCOUPLER ...
Korg Polysix direct replacement for OPTOCOUPLER HTV P-1501 PHOTOCOUPLER PC-1 | Musical Instruments & Gear, Pro A...
    En miércoles, 16 de mayo de 2018 4:28:58 CEST, Peter Foley petereugenefoley@gmail.com [PolySix] <PolySix@yahoogroups.com> escribió:
- Peter
note changes.
held note changes.
Is that correct?
