Another P6 back to life, but some issues are still there.
2013-10-22 by <rufushaw@yahoo.it>
Hi all there,
I've picked up another Polysix in good external conditions, but dead on the electronic side.
It had the common battery leakage on a small area not so bad than others that I've already repaired, so I've restored it at usual,
Now some minor issues are still there.
Octave scaling is irregular, so, suspecting a faulty HTV1501 photocopupler as written in other topics, I've swapped the voice board with a spare working one, and the issue disappeared, then the issue might be on PC1.
I can't understand which spare is better for this IC, someone says VTL5C1, some other says VTL5C3,
MG level doesn't works properly.
This issue is driving me crazy.
Frequency and Delay Pots are working flawless, but once engaged, it's impossible to dim or turn off the LFO modulation effect by turning the "level" pot.
The pot itself is working, either the IC2 4051 on control board is working, i've followed the Data and A B C cables for signals routing and they are without any interruption.
I've checked the IC6 also, perfect.
Connection cables are ok.
Tips about where to dig?
More than this, it doesn't save patches.
I've checked the memory chip's electrical signals, and it seems working properly, giving the same responses than the working one.
I have also made the Lithium battery mod as shown in service manual appendix, but there's no way to save patches,although the buttons are working properly.
Any help is very much appreciated, thanks.
Sorry for my bad english,
Bye,
RE: Another P6 back to life, but some issues are still there.
2013-10-23 by <rufushaw@yahoo.it>
Hi there,
Some updates.
I've made some swapping tests, and these are the result.
Broken P6 had some issues on panel controls, on octave transpose knob 16' 8' 4' and MG level knob.
I've swapped the KLM367 with a working one, and both these issues disappeared, so, the panel board with knobs is ok and the problem is somewhere on KLM 367.
I've ordered some Vactec VTL5C3/2 to change the PC1 IC, hope this will be enough to restore the voice board.
So questions are:
Which traces / ICs manage the OCTAVE TRANSPOSE switch 16' 8' 4'
Which traces / ICs manage the MG level pot values?
---In polysix@yahoogroups.com, <rufushaw@...> wrote:
Hi all there,
Bye,
2013-10-30 by <rufushaw@yahoo.it>
Hi all there,
Some updates:
MG LEVEL issue > Solved.
After getting crazy in debugging, I've swapped the 8047-347 (an 8947 with mask rom written on it) with a regular factory 8047. the issue disappeared.
Called the guy who copied the maskrom for me, he gave me another copy an this one works flawless.
WRONG SCALING issue:
is still there.
I've bought some NOS VTL5C3/2 photocouplers.
I've replaced the original HTV1510 mounting the VTL5C3/2 upside-down to match pinouts.
This doesn't solve the issue.
Measured the IC18 pin 7, obtaining 0V
After that, i've tried to replace the R39 with a 22K resistor. nope.
Placed back the original HTV1510 and original R39 resistor, measured again the IC 18 pin 7. obtaining 0V just as before.
IC 31 Replaced
IC 18 Replaced
IC 17 Replaced
I have no points to where i'm going nor where to go.
PATCHES MEMORY SAVING issue.
I haven't checked it at all, is still there just as before.
Hi there,
Some updates.
So questions are:
Hi all there,
Bye,
RE: [PolySix] RE: Another P6 back to life, but some issues are still there.
2013-10-30 by backshall1
I posted this link a couple of months ago. It's a blog by Stefan Huebner. He
took some measurements with an old P1501 and a couple of Vactrol parts and
made a nice chart showing response curves. His conclusion: The VTL5C9 is a
much closer match to the old P1501 than any of the parts we have been
trying. I think he may be right since I had trouble with a new VTL5C3 in one
Polysix not scaling properly and a VTL5C9 worked just fine. I've never used
the 5-pin VTL5C3/2 dual photocoupler, since there are only 4 pins on the
Polysix that are actually connected to anything.
 http://huebnerie.de/blog/?p=318
Don Backshall
  _____
From: PolySix@yahoogroups.com [mailto:PolySix@yahoogroups.com] On Behalf Of
rufushaw@yahoo.it
Sent: Wednesday, October 30, 2013 2:29 PM
To: PolySix@yahoogroups.com
Subject: [PolySix] RE: Another P6 back to life, but some issues are still
there.
 Hi all there,
Some updates:
is still there.
match pinouts.
IC 31 Replaced
IC 18 Replaced
IC 17 Replaced
Hi there,
Some updates.
So questions are:
Hi all there,
electronic side.
"level" pot.
working properly.
Bye,
RE: RE: [PolySix] RE: Another P6 back to life, but some issues are still there.
2013-10-30 by <hr.public@lonningdal.net>
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(Message over 64 KB, truncated)
2013-10-31 by <rufushaw@yahoo.it>
Hi all there,
that's the last update for today.
I've swapped the 8049-217 from a working P6 to the faulty one and there was a big change.
Now, tuning of notes from the faulty P6 doesn't sound scrambled anymore.
I've followed the tuning tips on service manual and there is a fixed drifting at the same intervals.
i.e.
C4 = C#5
C#4 = D5
D5 = D#5
and so on....
The 8049-217 taken from the faulty P6 mounted on the working P6 caused the notes to play scrambled just as the other one, so part of the issue came from there.
Now, on the faulty P6 (with working 8049-217) there's the old HTV1501 mounted on it, and the IC18 Pin 7 is still stuck at 0V.
I've checked the traces from and to the TC5514APL-3 memory chip and seems everything ok.
I've bought spares to replace t in order to verify if the issue is there.
Now i'ts late and i'll go to sleep.
Thanks a lot.
Sandro.
---In polysix@yahoogroups.com, <hr.public@...> wrote:
I can confirm VTL5C9 works fine without any modifications. Made this picture for reference.
http://i188.photobucket.com/albums/z222/minebildererdine/Synth/Korg%20Polysix/PolysixOpto_zps31d9ca46-1.png
---In PolySix@yahoogroups.com, <polysix@yahoogroups.com> wrote:
RE: RE: Another P6 back to life, but some issues are still there.
2013-10-31 by <kenichi.productions@gmail.com>
Hey Sandro,
Thats really interesting that most of your problems came from your CPU chips. Were they original or aftermarket replacements?
I had weird problems like these but mostly the past they have come down to the CPU socket, or D/A converters. haven't had to replace a CPU yet...
I would definitely put in the new opto coupler. Just really make sure of your connections. I think I had trouble with this one time. And then Retune following peoples advice here or by googling for polysix tuning procedures. I left my most recent one on overnight and touched it up continuously using a chromatic tuner and was able to get it really nicely in tune. I had also replaced all electrolytics on CPU and module board on this unit. There is the fine tuning for the middle of the key span as well which could help. D#-E# or something the trimmer says next to it....
With the RAM chips, usually swapping out the 5514APL has done the trick for me in the past. If not that try replacing the memory address decoder while your at it. Can't recall which IC that is off the top of my head.
Luke
Hi all there,
WRONG SCALING issue:
i.e.
C4 = C#5
C#4 = D5
D5 = D#5
and so on....
Thanks a lot.
Sandro.
2013-11-02 by <rufushaw@yahoo.it>
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(Message over 64 KB, truncated)
2013-11-17 by <rufushaw@yahoo.it>
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(Message over 64 KB, truncated)
RE: Another P6 back to life, but some issues are still there.
2013-11-27 by <rufushaw@yahoo.it>
Hi all there,
Some updates:
PATCHES MEMORY SAVING - Solved.
Swapped theTC5514APL-3 memory chip with a spare NOS one,
BATTERY MOD:
Memory backup battery works flawless, it keeps the memory data after several hours with power off and Main supply cable unplugged.
So, only two issues to repair remaining.
KEYBOARD SCALING
The NOS installed VTL5C9 doesn't solve the issue nor make any change in synth behaviour.
So, the issue isn't alleged to the PC1 part.
FIFTH VOICE PLAYS AT LOWER PITCH THAN OTHERS
Still under investigation, i've replaced or swapped between voices 4 and 5 almost all components on this voice section, still nothing.
Help is very much appreciated.
Thanks again
Bye,
---In polysix@yahoogroups.com, <rufushaw@...> wrote:
Hi all there, new updates.
ERRATA CORRIGE:
I've made a mistake about the value reading from IC18 pin 7, due to a wrong setup of the oscilloscope.
The actual output value is +15V
KEYBOARD SCALING ISSUE:
I've checked the A B C INH clock values from IC 12 on KLM366 to check VCF clocks.
I've checked the A B C INH clock values from IC 31 on KLM366 to check tuning section clocks.
PC1 replaced with brand new VTL5C9.
The issue is still there, so i guess the problem is somewhere in the assigner section.
As you can see in this pic,
http://img820.imageshack.us/img820/8370/87ux.jpg
I've already replaced some of the involved chips (IC17, IC18, IC31), before this replacement,
Any idea where to dig?
How can i test if the incoming signals from KLM367-A are ok to be sure that issue is located somewhere on the KLM366 assigner section?
Here some pics of the spare in place.
The spare has been mounted upside/down to match the Anode/Cathode pins.
http://img194.imageshack.us/img194/9278/vy3d.jpg
http://img842.imageshack.us/img842/1684/89ng.jpg
To kenichiproductions
Message 7 of 8 ,
The Mask rom were both original, maybe the huge shortcut area on KLM367 have corrupted the data.
Any help is much appreciated,
Thanks for support.
Hi all there,
Some updates:
16' 8' 4' pot issue solved.
The pot wasn't working properly due to a interrupted trace on KLM 367.
You can see the huge rework I've done the first day this P6 come into my lab.
The trace about the 16' 8' 4' pot is the one rejoined with the red cable.
I don't know if I can post here this link to the picture, if not, just tell me and I'll remove it.
http://imageshack.us/a/img607/7356/be7v.jpg
So, only three issues to solve remaining.
KEYBOARD SCALING - I'm waiting for the spares VTL5C9
FIFTH VOICE SOUNDING SO LOW IN OCTAVE - Under investigation, i've replaced or swapped between voices almost all components on this voice section, still nothing.
PATCHES MEMORY SAVING:
I've found another broken trace in the same area mentioned before, this one involving the TC5514APL-3 memory chip.
Trace has been restored, but the issue wasn't there.
I'm waiting for spares to replace it, i'll keep you posted about that.
QUESTION:
I've done the battery replacement mod to mount a CR2032.
I've replace the resistor R91 with a 1N4148 diode as i've read on oldcrow's page.
Here a pic of the area, does it seems correct to you?
http://imageshack.us/a/img823/5561/vmeo.jpg
Thanks again for help.
Bye,
---In polysix@yahoogroups.com, <kenichi.productions@...> wrote:
Hey Sandro,
Thats really interesting that most of your problems came from your CPU chips. Were they original or aftermarket replacements?
I had weird problems like these but mostly the past they have come down to the CPU socket, or D/A converters. haven't had to replace a CPU yet...
I would definitely put in the new opto coupler. Just really make sure of your connections. I think I had trouble with this one time. And then Retune following peoples advice here or by googling for polysix tuning procedures. I left my most recent one on overnight and touched it up continuously using a chromatic tuner and was able to get it really nicely in tune. I had also replaced all electrolytics on CPU and module board on this unit. There is the fine tuning for the middle of the key span as well which could help. D#-E# or something the trimmer says next to it....
With the RAM chips, usually swapping out the 5514APL has done the trick for me in the past. If not that try replacing the memory address decoder while your at it. Can't recall which IC that is off the top of my head.
Luke
---In PolySix@yahoogroups.com, <polysix@yahoogroups.com> wrote:
Hi all there,
that's the last update for today.
WRONG SCALING issue:
I've swapped the 8049-217 from a working P6 to the faulty one and there was a big change.
Now, tuning of notes from the faulty P6 doesn't sound scrambled anymore.
I've followed the tuning tips on service manual and there is a fixed drifting at the same intervals.
i.e.
C4 = C#5
C#4 = D5
D5 = D#5
and so on....
The 8049-217 taken from the faulty P6 mounted on the working P6 caused the notes to play scrambled just as the other one, so part of the issue came from there.
Now, on the faulty P6 (with working 8049-217) there's the old HTV1501 mounted on it, and the IC18 Pin 7 is still stuck at 0V.
PATCHES MEMORY SAVING issue.
I've checked the traces from and to the TC5514APL-3 memory chip and seems everything ok.
I've bought spares to replace t in order to verify if the issue is there.
Now i'ts late and i'll go to sleep.
Thanks a lot.
Sandro.
---In polysix@yahoogroups.com, <hr.public@...> wrote:
I can confirm VTL5C9 works fine without any modifications. Made this picture for reference.
http://i188.photobucket.com/albums/z222/minebildererdine/Synth/Korg%20Polysix/PolysixOpto_zps31d9ca46-1.png
