Polysix tuning difficulties.
2014-02-07 by <josh.nursing@gmail.com>
2014-02-27 by <josh.nursing@gmail.com>
2014-02-28 by Bob Grieb
As you know, there is just the one exponential convertor that is shared
by all of the voices. Maybe it's not calibrated correctly? If you have a problem
with all of the voices, then it must be something that is common to all of them,
right?
I can make measurements for you if you like. Mine seems to be working OK.
The tuning is not perfect, but it's pretty close.
Bob
________________________________From: "josh.nursing@gmail.com" <josh.nursing@gmail.com> To: PolySix@yahoogroups.com Sent: Thursday, February 27, 2014 5:30 PM Subject: [PolySix] RE: Polysix tuning difficulties. I have been through the tuning process a couple of times. Both times I hit the upper limit of tuning for most of the voices. One of the VRs when turned (and if memory serves me well, it might have been a global VR) does a strange thing: when I turn it CCW, the pitch goes down but then slowly rises again. When I turn it CW, the pitch rises but then slowly starts to drop. Thus, it's just not possible to tune the Polysix properly. I am not sure where the issue is but it looks to me it could be a capacitor acting up? I might have to check the VR as well. A couple of checks on the opto-coupler eliminated it as the source of potential issues: it is still functional. Yash
2014-02-28 by Malte Rogacki
The problem is that there is no guideline in the service manual for calibrating the antilog amp (before the multiplexer). I always wanted to find out about this in more detail because I'm sure this will affect the tuning precision over the whole range. I once had a Polysix on my desk with an antilog amp that was very mis-calibrated. It took me ages to get it into an acceptable tuning: The voices were mostly hitting the designated tuning "spots" but were out of tune in between. Imagine a diagram of a sine function - the tuning felt like that. The Korg Trident manual has a procedure for this but it is not very helpful (at least it didn't work for me). This is also a circuit part that differs between the voice board revisions. Perhaps it is possible to extract something from comparing it to the service instructions of other synths from that Korg era. As I said there is something about this in the Trident manual; and the MonoPoly manual also has instructions (of course the circuit differs). There must be some kind of procedure; I can't imagine they did this by trial and error at the factory.
2014-02-28 by <josh.nursing@gmail.com>
2014-02-28 by Dennis Matana
hi,
maybe the VR itself isn't what it use to be...maybe corroded....you could unsolder it and measure it through...if the VR isn't stable in its value tuning can be a b*tch ;)
http://soundcloud.com/wifi
www.facebook.com/matanateknik
On Friday, February 28, 2014 3:04 PM, "josh.nursing@gmail.com" <josh.nursing@gmail.com> wrote:
Do you think this would this explain why the VR is acting weirdly? Why does the pitch rise after a while after I have turned the VR anti-clockwise? It does exactly the same thing in the other direction.
Yash2014-02-28 by Malte Rogacki
At 6:03 Uhr -0800 28.02.2014, <josh.nursing@gmail.com> wrote: > Do you think this would this explain why the VR is acting weirdly? Why does > the pitch rise after a while after I have turned the VR anti-clockwise? It > does exactly the same thing in the other direction. I think this is more or less normal behaviour. There are three VR for the calibration of the antilog amp. All three interact somewhat. I do remember that the behaviour you describe was similar to some setting on my machines. If I find the time I'll look into this soon.
Does anyone have access to a complete (!) Trident Mk II service manual? Posting the procedure for the antilog calibration would help tremendously. I have the calibration routines for: Trident (Mk I) -> incorrect and partly implausible Poly-61 -> will have to check MonoPoly -> will have to check Can anyone think of other Korg Polysynths from that era that might use the same antilog technique? I think this is the list: Polysix Poly-61 MonoPoly Trident Trident Mk II It would seem odd to me that all of them have an antilog calibration routine except the Polysix. The Polysix also has a test point at the same circuit position...
The voltage at TP2, called Oct/V CV, which seems to be the input
to the antilog ckt, is constantly switching between 8 values. Six of them
are the same when you go into unison mode, but there are still two other
ones being muxed in. I guess for the factory calibration they must have had
a way to pause the muxing and put out specific DAC values for setting the
trimmers using a DMM. Seems like that code would be in the keyboard
MCU, unless they had a factory test MCU that they used.
Bob
________________________________From: Malte Rogacki <gacki@gacki.sax.de> To: PolySix@yahoogroups.com Sent: Friday, February 28, 2014 3:54 PM Subject: RE: [PolySix] RE: Polysix tuning difficulties. Does anyone have access to a complete (!) Trident Mk II service manual? Posting the procedure for the antilog calibration would help tremendously. I have the calibration routines for: Trident (Mk I) -> incorrect and partly implausible Poly-61 -> will have to check MonoPoly -> will have to check Can anyone think of other Korg Polysynths from that era that might use the same antilog technique? I think this is the list: Polysix Poly-61 MonoPoly Trident Trident Mk II It would seem odd to me that all of them have an antilog calibration routine except the Polysix. The Polysix also has a test point at the same circuit position...
Found this on the web: "The other test mode is started by jumpering pins DB7 and P17 using a diode (cathode towards DB7) on the 8049 processor on the KLM-366 circuit board (this can be done on the keyboard connector CN04). In this mode the CV DAC is set to generate 0V, 2.5V, or 5V depending on the position of the OCTAVE switch (16’ results in 0V, etc.). This mode is used to check the CV DAC and is not described in the service manual." I wonder if this could be used to set up the antilog circuit? Or possibly once in this mode, there are other voltage settings as well? Think I will try this out. Bob ________________________________
Hi, this reminds me of something. I believe at least the Polysix and the MonoPoly use the same assigner. Polysix 8049C217 Monopoly 8049C217 Same for the old revision of the Poly-61. The Poly-61 (being a 6-voice synth) could lend useful insights here. The MonoPoly has a "Tune Point Switch" that - as far as I can see - connects pin 34 to pin 19 for the initial tuning procedure.
> The voltage at TP2, called Oct/V CV, which seems to be the input > to the antilog ckt, is constantly switching between 8 values. Six of them > are the same when you go into unison mode, but there are still two other > ones being muxed in. I guess for the factory calibration they must >have had > a way to pause the muxing and put out specific DAC values for setting the > trimmers using a DMM. Seems like that code would be in the keyboard > MCU, unless they had a factory test MCU that they used.
At 14:27 Uhr -0800 28.02.2014, Bob Grieb wrote: > Found this on the web: > > "The other test mode is started by jumpering pins DB7 and P17 using a >diode (cathode towards DB7) on the > 8049 processor on the KLM-366 circuit board (this can be done on the >keyboard connector CN04). In this mode the > CV DAC is set to generate 0V, 2.5V, or 5V depending on the position of >the OCTAVE switch (16' results in 0V, etc.). > This mode is used to check the CV DAC and is not described in the service >manual." > > > I wonder if this could be used to set up the antilog circuit? Or >possibly once in this mode, there are > other voltage settings as well? Think I will try this out. That's exactly what the MonoPoly does! The Monopoly service manual however gives 0.000V Down Low Adjust 5.250V Normal Mid Adjust 10.583V Up Hi Adjust and takes the signal after the demultiplexer (and after the buffer and possible a 100R resistor). The octave switch in the Polysix should theoretically do the job.
Yes, it seems we can get three different static DAC values, but I am not sure that is enough to calibrate the anti-log circuit. I tried the test, and saw roughly 0,2.5 and 5V on the output of the DAC. I pressed lots of front panel switches. Other ones also affect the voltage, but it seems there are only three choices. Seems like you would want more voltages, and specific ones that were chosen for the job. The circuit in the Monopoly that is being adjusted is not logarithmic, it seems. Just a gain stage. ________________________________
From: Malte Rogacki <gacki@gacki.sax.de> To: PolySix@yahoogroups.com Sent: Friday, February 28, 2014 5:57 PM Subject: Re: [PolySix] RE: Polysix tuning difficulties. At 14:27 Uhr -0800 28.02.2014, Bob Grieb wrote: > Found this on the web: > > "The other test mode is started by jumpering pins DB7 and P17 using a >diode (cathode towards DB7) on the > 8049 processor on the KLM-366 circuit board (this can be done on the >keyboard connector CN04). In this mode the > CV DAC is set to generate 0V, 2.5V, or 5V depending on the position of >the OCTAVE switch (16' results in 0V, etc.). > This mode is used to check the CV DAC and is not described in the service >manual." > > > I wonder if this could be used to set up the antilog circuit? Or >possibly once in this mode, there are > other voltage settings as well? Think I will try this out. That's exactly what the MonoPoly does! The Monopoly service manual however gives 0.000V Down Low Adjust 5.250V Normal Mid Adjust 10.583V Up Hi Adjust and takes the signal after the demultiplexer (and after the buffer and possible a 100R resistor). The octave switch in the Polysix should theoretically do the job.
Yes, it's possible that the circuit in the MonoPoly isn't an antilog circuit; but still the calibration involves some scaling. It's apparently not completely linear, is it? As far as the three voltages go: This is exactly what the other antilog calibrations do, too. The Trident requires to press the same key 8 times to load the DAC with the same voltage. This is done for three different keys (C1, C3, C6). The Poly-61 uses unison mode but measures just for single voice (apparently after the demultiplexer). So my guess is that three voltages are indeed enough. If I'm not mistaken the antilog circuit for the Polysix has four trimpots (at least in the new version): one each for low, mid high and another one for a general offset. I think the old version only had three pots. At 15:08 Uhr -0800 28.02.2014, Bob Grieb wrote:
> Yes, it seems we can get three different static DAC values, but I am not >sure that > is enough to calibrate the anti-log circuit. I tried the test, and saw >roughly 0,2.5 and 5V > on the output of the DAC. I pressed lots of front panel switches. >Other ones also affect the voltage, but it seems there are only three >choices. Seems like you would want more voltages, and specific ones that >were chosen for the job. The circuit in the Monopoly that is being >adjusted is not logarithmic, it seems. Just a gain stage.
2014-03-01 by Ben Stuyts
Hi, There is some Trident MkII stuff in the files section in this group. Including some tuning info. Kind regards, Ben
On 28 feb. 2014, at 21:54, Malte Rogacki <gacki@gacki.sax.de> wrote: > Does anyone have access to a complete (!) Trident Mk II service manual? > Posting the procedure for the antilog calibration would help tremendously. > > I have the calibration routines for: > > Trident (Mk I) -> incorrect and partly implausible > Poly-61 -> will have to check > MonoPoly -> will have to check > > > Can anyone think of other Korg Polysynths from that era that might use the > same antilog technique? I think this is the list: > > Polysix > Poly-61 > MonoPoly > Trident > Trident Mk II > > It would seem odd to me that all of them have an antilog calibration > routine except the Polysix. The Polysix also has a test point at the same > circuit position... > > > ------------------------------------ > > Yahoo Groups Links > > >
2014-03-01 by Malte Rogacki
Thanks. This is similar to what I did to get the mis-calibrated Polysix back in tune. There are two problems with this though: 1. If the calibration of the voice is off the mark it won't work reliably. 2. If the calibration of the "middle" antilog is off the mark it won't work reliably. And this can be a big issue: If the antilog wasn't properly calibrated to begin with it's quite likely that someone will have tried to tune the voices but hit extreme positions and so on. The calibration procedures for the Trident Mk I, the Polysix and the MonoPoly give definite voltages for which to calibrate. This has the advantage that afterwards you have a perfectly calibrated voltage source. At 1:10 Uhr +0100 01.03.2014, Ben Stuyts wrote:
> There is some Trident MkII stuff in the files section in this group. >Including > some tuning info.
2014-03-01 by <chipaudette@yahoo.com>
While indeed the oscillator has a different design it should still be possible to get the antilog amp calibrated better. I actually think that the whole test mode isn't even needed: What we actually need is the defined voltage coming from the DAC and then the target voltage for a single note after the demultiplexer. This seems to be the procedure for the Poly-61 (it uses unison mode so that all voices have the correct voltage). This should nicely circumvent the problem that there are two unused voices with the 8049C217. The Trident measures the voltage for all 8 voices together in front of the demultiplexer; hence it is necessary to press a single key eight times. However I don't know if the antilog amp somehow has to account for non-linearities in the oscillators. I'll give this some more though later. At 6:45 Uhr -0800 01.03.2014, <chipaudette@yahoo.com> wrote:
> The Mono/Poly uses a completely different VCO design. The Mono/Poly has > Volt/Octave VCOs instead of the Volt/Hz found in the Polysix. So, the tuning > issues are very different. > > As a result, I don't think that the Mono/Poly will be much help for >insight on > how to recover the tuning on a Polysix.
2014-03-02 by Malte Rogacki
Another idea: They built in three TPs that are only useful for calibrating the antilog amp. TP4 first caught my eye. This is -10V. With the Trident you were required to attach the multimeter ground point to a -11V point. All the following measurements are done on a new production voice board. I checked what happens when connecting P17 to DB7 with a diode. The voltage at TP2 went 16': -8.62 8': -11.22 4': -13.33 Now, TP2 is conveniently labelled "Oct/V CV" while TP3 is labelled "Hz/V CV". Voltage at TP3 is: 16': -9.94 8': -8.75 4': +4.20 Now, if we connect the multimeter ground probe to the aforementioned TP4 we get (more or less as expected): 16': +0.03 8': +1.23 4': +14.19 That this doesn't up a 100% with the TP3 voltages may have something to do with the voltage on TP4 not being 10.00V. Anyway; I think somewhere around this must be the crucial point for the calibration. It should also be noted that the voltage at the "OCT/V CV" TP2 is NOT 1V/Oct. It's pretty precisely 0.5V/Oct. This is also visible in the service manual on the page for the old production key assigner. I have the feeling we're getting closer. Perhaps the factory used a "dummy plug" with the diode connecting P17 and DB7 instead of the keyboard for calibrating the antilog amp. Given the fact that they also had another dummy plug with the 56k resistor for calibrating the reset circuit I find this not unlikely.
Measurements on and old production board. TP2 and TP3 are obscured by the KLM396A board which must be removed. TP2 16': -8.40 8': -11.02 4': -13.30 TP3 16': -9.93 8': -9.39 4': -2.40 TP3 with ground probe at TP4 16': +0.03 8': +0.97 (somewhat unstable occasionally more around +0.60) 4': +14.20 The last pair is a a bit of a mystery to me. Perhaps my multimeter is freaking out.
And one final thought before I retire for tonight: I don't think the test mode for the key assigner puts out 0, 2.5 and 5V respectively. The test mode for the MonoPoly put out a much larger voltage than the whole keyboard required. And it was not directly related to the CV. Monopoly: 0V 5.25V 10.583V Polysix new: -8.62 -11.22 -13.33 Polysix old: -8.40V -11.02V -13.30V This also did not correspond with the regular key voltages (0.5V/Oct). If I try to relate the numbers by removing the offset I get for the Polysix: Polysix new: 0V 2.6V 4.71V Polysix old: 0V 2.62V 4.9V It's obvious that the two top values don't fit into this. For the Monopoly the ratio for middle value to top value was 1 to 2.015. For the new Polysix it was 1 to 1.811. For the old Polysix it was 1 to 1.870. Anyway, since for both the Monopoly and the Polysix the values are somewhat odd I could imagine that those values were picked to simplify the antilog calibration. However in the Monopoly this makes not much sense (you have to calibrate to those three values to get regular 1V/OCT response - why not use values like 5V or 10V then?) I could imagine that this is a Polysix "thing".
And here's the voltage for all "C" keys, starting from the lowest C and 16' to the highest and 4'. Measured on the new production board, after the demultiplexer. Stretch tuning is off (this is important!). Multimeter ground is TP4 (-10V). 0.018 0.042 0.090 0.185 0.375 0.755 1.513 3.03x The doubling of the voltage for each octave is easy to see. I think this antilog amp has a good calibration; perhaps at the bottom there is a little bit of room for improvement. So we have essentially a doubling for every 0.5V at the input. With VR1 to VR3 we can change the relation of those voltages for certain areas. The service manual says: VR1 ADJ. CENTER VR2 TUNE HIGH VR3 TUNE LOW VR15 TUNE MID However I'm not a 100% convinced that the functionality of VR15 and VR1 isn't switched. VR15 seems to control a general offset while the other VR's indeed control their respective ranges. They're affecting the tuning a bit outside their range but not much. A comparison of the old and new production also hints at this: VR1 MID VR3 LO There seems to be no VR2 for the old production. And the addendum says "VR15 on KLM-366 is equal to VR1 on KLM-396." The latter is the daughterboard for the old production; hence VR15 is NOT the same as VR1 (which is simply labelled "MID") on the old production KLM-366. So my guess is that the four VR's for the new production should better be labelled: VR1 TUNE MID VR2 TUNE HIGH VR3 TUNE LOW VR15 ADJ. CENTER
I've managed to improve the scaling a bit. Before: 0.018 0.042 0.090 0.185 0.375 0.755 1.513 3.03x After: 0.023 0.045 0.090 0.182 0.366 0.740 1.490 2.98x VR1 has the least effect; that's the one that has the tuning "drift back" a bit after adjusting it. But it doesn't go back completely. Admittedly VR2 is now in its extreme position. There probably is still room for improvement. It would be nice to have a definite table for all this. I've done all the measuring with the "Tune" knob in the middle and the pitch wheel centered. This voltage is also part of the calibration;so if you have the tuning knob in a different position you'll end up with different values.
And finally: I've tuned the Polysix (so far just preliminary). There still is some small room for improvement but except for the lowest 16' octave I have a pitch deviation better than the one shown in the service manual. Some notes have a 1 to 2 cent deviation but most are spot on. The lowest notes in the lowest octave have currently a deviation of about 7 cent. I had to use VR15 a lot though which means that probably the basic offset was not so good. The whole antilog circuit calibration could probably be shifted a bit upwards and then compensated for again with VR15. This could possibly bring VR2 away from its end position.
2014-03-02 by Bob Grieb
Good work! My tuning is pretty close, but I have not touched the antilog trimpots, so I am looking forward to getting this really nailed so that I can get it even better, as you did. One thing I don't understand is how the 4051's are being used to change the behavior of the circuit. And what is the fcn of the opto-coupler? Any thoughts? Bob ________________________________
From: Malte Rogacki <gacki@gacki.sax.de> To: PolySix@yahoogroups.com Sent: Sunday, March 2, 2014 9:05 AM Subject: Re: [PolySix] RE: Polysix tuning difficulties. And finally: I've tuned the Polysix (so far just preliminary). There still is some small room for improvement but except for the lowest 16' octave I have a pitch deviation better than the one shown in the service manual. Some notes have a 1 to 2 cent deviation but most are spot on. The lowest notes in the lowest octave have currently a deviation of about 7 cent. I had to use VR15 a lot though which means that probably the basic offset was not so good. The whole antilog circuit calibration could probably be shifted a bit upwards and then compensated for again with VR15. This could possibly bring VR2 away from its end position.
Hi, I have uploaded a redrawn schem of the Poly6 antilog circuit. I hope this will help anyone who is working in this area. If we learn more about how to adjust the trimmers, I will add it to the schematic. The 17.5 mV/oct value was lifted from a clear copy of the older key assigner schem. It finally hit me that IC30 is for detuning the voices in Unison mode. Duh! Not sure why I didn't think of that before. Bob ________________________________
This is just from the top of my head: The optocoupler is in a feedback loop from the demultiplexer output to the antilog amp. If I remember correctly there are two unused "slots" in the DAC (and hence two "unused" multiplexer outputs). But those two "slots" are always at the same fixed value (I think). By using such a feedback loop it should be possible to account for any changes to the circuitry (temperature, voltage...) because this output would carry the changes and hence counter them in the optocoupler. I haven't checked what exactly the second "unused" multiplexer output does. That's the one that leads back to vicinity of the 4051 in front of the antilog amp (or the one on KLM-396 for old production boards). At 6:15 Uhr -0800 02.03.2014, Bob Grieb wrote:
> One thing I don't understand is how the 4051's are being used to change the > behavior of the circuit. And what is the fcn of the opto-coupler? Any > thoughts?
Hi Malte,
As you said, there are two "extra" time slots that are constantly being stepped through by the ABC mux select signals. (I checked with a scope this morning) These are slots 6 and 7.
Time slot six connects the output of the converter to the opto-coupler feedback circuit.
The RC time constant of 330K/47 uF is 15 seconds, so this would be a slow correction,
not quick feedback. This feedback affects the mv/oct scale at the input of the converter
by adjusting the R98/R85 voltage divider. I am wondering if this feedback is more for the higher frequencies (lower output voltages) since the Tune High VR affects it.
Time slot 7 also feeds back, through IC18-1,2,3 Again, the time constant at the output is about 5 seconds, so this is also a slow feedback path. This one seems to affect the "center" setting, as it feeds an offset voltage, instead of changing the input attenuation. When this feed back is selected, VR15 is also enabled, so I guess it makes sense that this would be a "center" feedback.
Bob
Sent: Sunday, March 2, 2014 1:40 PM
antilog amp.
At 6:15 Uhr -0800 02.03.2014, Bob Grieb wrote:> One thing I don't understand is how the 4051's are being used to change the > behavior of the circuit. And what is the fcn of the opto-coupler? Any > thoughts?
That schematic is very nice and very helpful. That particular portion of the service manual from the files section isn't the most readable. One thing that immediately becomes clear to me now is that IC19 generates the -10V rail. R26 (at the right) would also connect directly to this rail but perhaps it's easier to read the way it is now.
The multiplexer/demultiplexer thing: Correction voltage from VR1 enters IC39 X7. This voltage must come back from IC31 X7 through IC18 at the bottom left of your schematic. The two controlling signals for this seem to be MUXSELA for the Offset correction (X7) and INH for the other correction (X6 to optocoupler).
I wrote my last reply, sent it, checked my mail and there was your description of the same circuit, just much better. :-)
2014-03-02 by <john_terhorst@yahoo.com>
In the description of the MG-1 Radio Shack/Moog synth, they discuss the need for
"high frequency compensation". This has to do with the fact that in the oscillator, usually they allow a fixed time for discharging the main integrator cap, whereas the charging time varies with frequency. So at higher frequencies, the discharge time becomes significant and the pitch is too low. I wonder if the opto-coupler circuit
corrects for this in the P6.
Bob
________________________________From: Malte Rogacki <gacki@gacki.sax.de> To: PolySix@yahoogroups.com Sent: Sunday, March 2, 2014 2:13 PM Subject: Re: [PolySix] RE: Polysix tuning difficulties. I wrote my last reply, sent it, checked my mail and there was your description of the same circuit, just much better. :-)
2014-03-02 by Ben Stuyts
Hi John, Thanks for being a member of the group for all these years. Hope you are well, and take care! Ben (Moderator)
On 2 mrt. 2014, at 20:23, john_terhorst@yahoo.com wrote: > > > After so many years I bid you wonderful Poly 6 people adieu. This is a great resource and a benefit to all Poly 6 owners. > >
I checked the DAC value at IC9-1 during time slot 6. It's always the same and corresponds to the very top C key when the octave switch is in the 4' position. On my unit it's about 3.6 volts. So the opto-coupler circuit would be looking at the conversion of that voltage. Those two long RC's explain why notes played during the first few seconds after power up are sliding around. Reply via web post Reply to sender Reply to group Start a New Topic Messages in this topic (32) Visit Your Group • Privacy • Unsubscribe • Terms of Use .
2014-03-02 by <josh.nursing@gmail.com>
This behaviour is somewhat normal. Please try the following: Put the Polysix in manual mode. Tuning knob centered, pitch wheel centered, no LFO modulation. Switch to Unison mode. Please measure the voltage at IC31, pin14 for each "C" from bottom 16' to top 4'and post that here.
I forgot: Please put the ground connection of the multimeter at TP4 (-10V).
And stretch tuning needs to be off - put the switch away from the connector.
2014-03-03 by <josh.nursing@gmail.com>
To use only one expo, Korg has used multiplexers to feed the 6 VCO CVs to the expo, followed by a calibration voltage and then the CV for standard pitch (only for the new production voice board).
The two latter outputs are routed to two independent controllers; the last one introduces an offset to the expo input to shift the standard pitch to its desired value, while the converted calibration voltage drives a current through the photocoupler’s LED, while its LDR is placed where you would normally expect the 3300ppm tempco resistor in similar circuits.
This leads to an eady way to check whether a tuning problem is related to the photocoupler circuit at all: measure the voltage on pin 7 of IC18. Within regulation it should be somewhat between -2 and -6 volts, -3 are more normal.
When the loop breaks open due to failure of the photocoupler or related parts, it will be stuck on the maximum negative output, something around -13 volts. There must always be a small current through the LED, otherwise the loop does not work and the TUNE HIGH preset has no effect!"
2. From Chip's blog: http://synthhacker.blogspot.ca/2013/02/polysix-basic-key-assigner-timing.html
"Looking at this graphs, I see that overall timing loop is 6204 microseconds ("usec") long. This means that the basic pitch and the on/off gate of each voice only get updated every 6.2 milliseconds, which is an update rate of only 161 Hz. Frankly, I was surprised at how slow this is. But, since the synth sounds OK, I guess that it works fine. Luckily, the pitch modulations and the VCF and VCA envelopes are not at all dependent upon this loop (they have their own generators which, for the case of the VCF and VCA, are fast).
Additional examination of these graphs (and a little more probing of the synth) allows one to understand the timing cycle well enough to break it into discrete time periods. Clearly, there are six periods associated with the pitch of the six voices. I call these periods "V1" through "V6". These periods are each 676 usec in duration.
After V6, there are appears to be another voice-like period, which I call "Vx7", since it is so much like a voice, but doesn't actually sound. Interestingly, through additional experiements, I found that its voltage is always the same - it is always set to be C7, the highest note on the Polysix. Vx7 is 712 usec long. Why is it a different length than V1-V6? I don't know.
Similarly, after Vx7, there appears to be another voice-like period, which I call "Vx8". Its voltage level always appears to be identical to V1. I don't know why. I'm thinking that Vx7 and Vx8 are both used by the Polysix's pitch correction circuitry to help it stay in tune. The duration of Vx8 is only 624 usec (though the end of Vx8 is actually a bit hard to define and measure).
After Vx8 is the final period of the Key Assigner's timing cycle. I call it the "Inter-voice" (or "IV") period. During this period, the synth sets the gate signals, it drives some LEDs, it scans the keybed and some switches, and probably a few other things as well. We'll dig into that in a future post."
2014-03-03 by Malte Rogacki
I think you need a more precise multimeter for this. Right from the reading I'd say the scaling is slightly off and the tuning could be slightly flat toward the top. You'll notice that the doubling usually ends with one number lower than expected. I've just did another test - I intentionally miscalibrated both antilog amp and the voices. Within about 20 minutes I was able to get the tuning back within the standard deviation chart. A better tuning might take a bit longer. I found the target voltages a little bit higher than your measurements. I started out with the VR1 to VR3 and VR15 roughly centered. Then I tried to get the highest note of the 16' setting close to 0.750 and then worked from there. I currently have the voltages as follows: 0.023 0.046 0.093 0.186 0.375 0.750 1.502 3.00 This results in a comparatively satisfactory tuning with no tuning VR in its extreme position. I initially used VR15 to get close to the 0.750 value. VR1 is only useful for very small finetunings; I think it affects the 0.750 setting (which I consider roughly "the middle" about +/- 2mV. For tuning I use the following procedure: I start with the first voice and tune 4' C6 as described in the manual. Then I press C2 six times so I'm back at the first voice and adjust VR10 as described in the manual. Without releasing the key I switch to 16' and adjust according to the manual. This will usually again affect the previous setting so I'll switch back to 4', make adjustments, switch back to 16', make adjustments and so on. It usually takes about ten to 20 steps until I'm close. After this I'll usually recheck 4' C6 for that voice, readjust and repeat the procedure. Once the first voice hits all relevant notes with 1 cent or less deviation I'm tuning the remaining voices. This is now much faster because I don't have to worry about the VR15 setting for the remaining voices. So it's just top and bottom. If I was in your place I'd probably try to turn VR15 slightly to the left to increase all voltages a bit.
Another mistake again: At 23:25 Uhr +0100 03.03.2014, Malte Rogacki wrote: > I start with the first voice and tune 4' C6 as described in the manual. > Then I press C2 six times so I'm back at the first voice and adjust VR10 as > described in the manual. This should read "and adjust VR15 as described in the manual". This is step 4 of the tuning instructions. In the service manual this describes KLM-396 VR1 (the VR on the small daughterboard); this is the same as VR15 for the new production voiceboards.
At 14:36 Uhr -0800 03.03.2014, <josh.nursing@gmail.com> wrote: > I will have to check if I haven't mistaken VR1 for VR15. > > My board is a new production one. VR1, VR2 and VR3 are next to the strech tuning switch. VR15 is directly left from the first voice on the new production board. For new production boards step 4) if the tuning instructions should read: "Play C2 and adjust VR15 to obtain 0 cent. Do this for one unit." There is a pretty good chance that following this instruction will already bring you back into a more friendly territory tuning-wise.
2014-03-04 by <josh.nursing@gmail.com>
